Please take a look at this report from MediaInfo
As you can see the video track is 22:03 as well as both audio tracks, and there is no delay. Subtitle tracks are 22:04 (still no delay) and 18:58 for the forced subtitle track (no delay either). However in the general tab duration is 25:50 ? Windows also reports a video duration of 25:50, but MPC reports 22:03. Do you know why this is happening? Have I made a mistake muxing this file?Code:General Unique ID : 73535907160229785234708819762834513689 (0x375280249E617293C7E518D10C8F1F19) Complete name : Y:\Television\Scrubs\Season 5\S05E24 - My Transition.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 334 MiB Duration : 25 min 50 s Overall bit rate : 1 804 kb/s Encoded date : UTC 2019-09-03 20:47:38 Writing application : mkvmerge v33.1.0 ('Primrose') 64-bit Writing library : libebml v1.3.7 + libmatroska v1.5.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 22 min 3 s Bit rate : 1 721 kb/s Width : 712 pixels Height : 574 pixels Display aspect ratio : 4:3 Original display aspect ratio : 5:4 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.168 Stream size : 271 MiB (81%) Writing library : x264 core 158 r2984 3759fcb Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=1 / chroma_qp_offset=-4 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.10 / aq=1:0.50 Default : Yes Forced : No Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 22 min 3 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 30.3 MiB (9%) Language : English Service kind : Complete Main Default : No Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 22 min 3 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 30.3 MiB (9%) Language : French Service kind : Complete Main Default : Yes Forced : No Text #1 ID : 4 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 22 min 4 s Bit rate : 8 098 b/s Count of elements : 358 Stream size : 1.28 MiB (0%) Language : English Default : No Forced : No Text #2 ID : 5 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 22 min 4 s Bit rate : 7 328 b/s Count of elements : 337 Stream size : 1.16 MiB (0%) Language : French Default : No Forced : No Text #3 ID : 6 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 18 min 58 s Bit rate : 95 b/s Count of elements : 5 Stream size : 13.3 KiB (0%) Language : French Default : No Forced : Yes
I think the "Duration" of the tracks is not counted from a virtual point zero on the timeline but from the first packet of said track. In case of a subtitle track that would be its first line. So it is possible for the first line of e.g. the Track with ID 6 to be at 06m52s. Then because the "Duration" is 18m58s the end would be 06m52s+18m58s=25m50s. So it would not be an error of MediaInfo or MKVToolNix but a misinterpretation by the user. The "fix" would be to remove any lines/line endings after 22m3s.
Well unless MPC is doing some weird magic, I should be able to tell by watching the video. It ends at 22:03 and the last subtitle appears at 21:27. Considering MediaInfo reports a duration of 25:50 I would expect MPC to play for that duration, including 3:47 minutes of black frames at the end, and a final subtitle somewhere near the end that would explain this extra duration.
EDIT: But I've recently had trouble with VsRip, could be that the subtitle track has dangling information, not real subpic but garbage data maybe. -
I've extracted the subtitle tracks with a different software and everything is in order, def something wrong with VsRip. Thanks for the pointers sneaker.
What does "in order" mean?
You could try MKVToolNix GUI's Info tool. Look into the last clusters to see what track(s) they belong to and what timecodes they have.Last edited by sneaker; 4th Sep 2019 at 17:05. Reason: Info tool, not Header editor
MediaInfo and Encore Disagree on Video Length
By koberulz in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2018, 07:54 -
QUERY: MKV and TS versions of same file reporting different sizes in Toast?
By amckinney in forum MacReplies: 2Last Post: 28th May 2017, 15:56 -
MP4 File - MediaInfo only shows file size. Encrypted maybe?
By bbabraham in forum Software PlayingReplies: 8Last Post: 18th Sep 2015, 17:59 -
corrupt .mts file (incorrect length)
By sandergoorden in forum Video ConversionReplies: 55Last Post: 30th Apr 2015, 09:56 -
VOB file displays "1 sec" length, is actually 29mins, plays full length but
By neonnebula in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2015, 21:12
