Bear for me to ask this true dummy-question:
All the clips stays on screen when I've finished capturing one tape and start a new one, even though I set a new capture-folder. I cannot find something like "New project" or "New tape" - I would like a blank canvas when I start capturing a new tape.
How to do?
/Peter.
I just started capturing some Hi8 tapes and noticed this as well. I just have Scenalyzer go to a "capture" folder, then when I'm done with a tape I close Scenalyzer, copy the files from "capture" to another folder that describes what is on the tape, and restart Scenalyzer which now has a blank slate.
Thanks, peasantdave
I ended up doing something likewise. However, you can set the capture folder in Scenalyzer, so no need to copy the files. After capturing one tape I simply click the wide "capture-folder" button on top, create a new folder for the next tape, go into that folder, close Scenalyzer and starts it up again. Then it's already in the right folder when it starts again with a blank slate.
Also, Scenalyzer has a pretty smart function which will rewind the tape and start capturing right away. However, I found that this function sometimes works correctly, but sometimes it only rewinds a little and the starts capturing (not at the beginning of the tape).
/peter.
Scenalyzer: *** Error:cc:can't connect: 345
By malling in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Sep 2019, 13:13 -
Scenalyzer Reports Wrong HDD Size and Operates Much Slower on New Computer
By Armandoban in forum Capturing and VCRReplies: 6Last Post: 23rd Mar 2018, 09:01 -
Scenalyzer problems.
By digicube in forum Capturing and VCRReplies: 1Last Post: 25th Feb 2017, 23:59 -
mkvmerge gui crashes on start/won't start
By buck09 in forum Blu-ray RippingReplies: 7Last Post: 1st Nov 2015, 23:43 -
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12
