Hi Guys,
Im new here. I have video 3840 x 2160 pixels and I used pinnacle studio 22 ultimate for editing my video and I will say it is ok on editing but when it comes in an output it is blurred even my video is clear. I tried H264 1080p 30mbit/s 29fps on 6mins for 700mb. Am I doing wrong thats why my output is blurred? If not, what should I do? Do I need to change my video editor? What do you suggest for a good video output?
Thanks in advance.
Are you viewing on a UHD display ? There's going to be significant loss resizing 3840 x 2160 to 1920x1080 . You're almost throwing away 3/4 of the information . Try the same dimensions as the input 3840 x 2160 and a higher bitrate
Other possibilities - maybe your project wasn't setup correctly with mismatched framerates , maybe your editor is blending frames . You'd have to check the specs for the video , the project settings, and export settings
Do D8 camcorders output dv macroblocks through their s-video output?
By Bassquake in forum Capturing and VCRReplies: 5Last Post: 1st Aug 2018, 04:37 -
I can't see difference between lossless UT video HDMI capturing, and AVCHD
By Stears555 in forum Capturing and VCRReplies: 2Last Post: 20th May 2016, 07:46 -
"XLL output not lossless"
By nixiejames in forum AudioReplies: 1Last Post: 8th Apr 2016, 06:20 -
New lossless video codec
By JanKafka in forum ProgrammingReplies: 13Last Post: 23rd Jun 2015, 16:16 -
Premiere export to lossless is not lossless
By Dogway in forum EditingReplies: 66Last Post: 30th Dec 2014, 13:48
