Often (but not always) at cold boot, there is a pause of about 10 seconds at the bios screen with no messages and then there is a reboot and windows start normally. Restarting windows also works without issues. Any ideas what might causing this problem?
Results 1 to 26 of 26
try unplugging any USB drives and have just the keyboard & mouse plugged in
and see if that helps. what are the specs of your computer and how much ram does it have ?? -
Problems on a cold boot may indicate something on the motherboard is failing and may fail completely soon. Maybe a bad cap. A can of freeze spray may help isolate the failing component.
Or maybe a bad drive. Check SMART stats.
Sometimes a bad cable or connector. -
Could also be a failing PSU or bad RAM. Turn on and watch the full BIOS startup sequence, especially the RAM check. You might also try setting your BIOS to all the defaults. Check your manual for instructions.
Unplugging USB drives does not help. It's an Z97 motherboard with an i5 CPU and 16GB RAM.
SMART status seems OK. Cables also seem OK.
BIOS does not display diagnostic messages such as RAM check. I already tried setting BIOS to default values without luck. -
try restarting your computer in safe mode and see if you still get the pause issue.
Most new MBs have utilities to setup and test the components. Run those if you have them as it may help pinpoint issues.
Here's the utilities for your board: https://www.gigabyte.com/Motherboard/GA-Z97X-Gaming-5-rev-10/support#support-dl-utility
The problem you're going to have is that by the time you get to the BIOS your computer will have warmed up enough to run normally.
The Intel Extreme Tuning Utility (XTU) has a Stress Test.
While you're at it, you should check and update your BIOS to the latest if you haven't already done so.
Other than that, it's the usual PC diagnostics routine. Remove/disconnect everything, including the RAM and HDD and start putting them back one by one.. Boot without the HDD and see if get to the screen where it says there's no OS, then reboot with a live Linux flash drive or disc to see if it hangs there. My first guess is still a bad RAM stick as I've had builds hang and restart like you're experiencing because of a bad stick.Last edited by lingyi; 31st Aug 2019 at 21:16.
There has not been a bios update for years. I also doubt it's a RAM problem (I am using new memory sticks that are already tested).
Do you have system speaker that gives a single beep while POST runs?
if not, get one.
Have you tried loading BIOS [original] afresh?
I did both when faced with similar problem.
@jagbo's suggestions are important and I had faced problem with cables/connectors.Sword is no substitute for kitchen-knife. -
Sometimes reboots mean your system has issues trying to run the ram at the desired settings,try lowering the setting to see if that helps.
I do have a system speaker that gives a single beep while POST runs and there no additional beeps.
I have already tried loading BIOS defaults settings.
I am already using 1600MHz RAM at 1333MHz. I will change settings to 1600MHz to see if it makes a difference. -
No. I had meant refreshing Flash BIOS as explained here
Caution: Please do not attempt, if you are not familiar with this process and the complications.Sword is no substitute for kitchen-knife. -
I believe I isolated the problem with an optical drive. The problem does not happen if I remove the drive and happens if I connect it to a different port/cable on the SATA motherboard controller. I think the problem shouldn't be the port/cable, but I will probably need a new drive in place of the old one to be certain.
I had faulty SATA cables in the last 15 years, at home and also at work, I just disconnected the optical drive and the computer started fine, replaced the SATA cable and it started just fine. Several computers. I don't know why, which pin connection is faulty and what exactly is wrong the cable.
EzGrapper doesn't work after reboot ????
By ksor in forum Capturing and VCRReplies: 6Last Post: 9th Feb 2019, 09:54 -
premiere cc weird behavior at the cold boot
By rama in forum EditingReplies: 0Last Post: 5th Feb 2017, 04:33 -
SOLVED. Random reboot with no warning. HELP!
By jollyjohn in forum ComputerReplies: 3Last Post: 20th May 2016, 03:31 -
By jollyjohn in forum ComputerReplies: 17Last Post: 4th May 2016, 12:09 -
Internal 2nd 3.5" sata HDD always unallocated after reboot
By Gurd99 in forum ComputerReplies: 8Last Post: 2nd Aug 2015, 10:42
