  1. How do you rotate a video in Staxrip?
    I need to rotate a video to the right so it's correct
    Mar 2008
    Either add TurnRight and TurnLeft to the filters profile,
    or handle this in an Avisynth script and feed the script to StaxRip as the source file
  3. Unless you want to rotate it 90, 180, or 270 degrees as explained by davexnet, you'll need the Rotate filter. Then you can rotate it by however many degrees you like. But I have no idea how to do that using StaxRip. In a regular AviSynth script it's easy:
    Rotate(15)
