Results 1 to 9 of 9
  1. Ok, I guess the new version of GomPlayer already has AV1 codec built-in feature.
    Question is how to play AV1 codec videos in and old version of GomPlayer?
    I'm reluctant to update versions of some softwares and I'd like to keep current one (2.3.21.5278).
    It's common to happen that newer versions are worse than what the previous one.
    Youtube is using this new codec in some videos when I download them with InternetDownloadManager.
    Any ideas?
    I can play such videos using VLC v. 3.0.7.1, but can't do the same with GomPlayer.
    Is there a way to install that codec to the whole system?
    I'm still using Windows 7 SP1.
    Thanks.
    Thank you.
    Mar 2008
    LAV filters can decode av1. Can GomPlayer use directshow codecs ?
  3. If GomPlayer can use DirectShow codecs and you can find a DirectShow AV1 decoder -- that should work. Can you give a link to a Youtube video that uses AV1? I haven't seen one yet.
    Mar 2008
    https://www.youtube.com/watch?v=k2qgadSvNyU
  5. Originally Posted by davexnet View Post
    Thanks for that. Are the AV01 streams AV1?
    C:\Youtube-dl>youtube-dl -F https://www.youtube.com/watch?v=k2qgadSvNyU
    [youtube] k2qgadSvNyU: Downloading webpage
    [youtube] k2qgadSvNyU: Downloading video info webpage
    WARNING: Unable to extract video title
    [youtube] k2qgadSvNyU: Downloading js player vflB-cY7Z
    [info] Available formats for k2qgadSvNyU:
    format code  extension  resolution note
    249          webm       audio only DASH audio   60k , opus @ 50k, 1.42MiB
    250          webm       audio only DASH audio   78k , opus @ 70k, 1.86MiB
    140          m4a        audio only DASH audio  130k , m4a_dash container, mp4a.40.2@128k, 3.47MiB
    251          webm       audio only DASH audio  150k , opus @160k, 3.64MiB
    160          mp4        256x144    144p  110k , avc1.4d400c, 25fps, video only, 2.28MiB
    278          webm       256x144    144p  122k , webm container, vp9, 25fps, video only, 2.49MiB
    242          webm       426x240    240p  221k , vp9, 25fps, video only, 4.78MiB
    133          mp4        426x240    240p  360k , avc1.4d4015, 25fps, video only, 5.55MiB
    243          webm       640x360    360p  406k , vp9, 25fps, video only, 8.58MiB
    395          mp4        426x240    240p  693k , av01.0.00M.08, 25fps, video only, 7.82MiB
    134          mp4        640x360    360p  718k , avc1.4d401e, 25fps, video only, 10.56MiB
    244          webm       854x480    480p  765k , vp9, 25fps, video only, 13.32MiB
    135          mp4        854x480    480p  939k , avc1.4d401e, 25fps, video only, 15.46MiB
    396          mp4        640x360    360p 1377k , av01.0.01M.08, 25fps, video only, 13.83MiB
    247          webm       1280x720   720p 1508k , vp9, 25fps, video only, 24.07MiB
    136          mp4        1280x720   720p 1625k , avc1.4d401f, 25fps, video only, 23.69MiB
    397          mp4        854x480    480p 2425k , av01.0.04M.08, 25fps, video only, 22.17MiB
    248          webm       1920x1080  1080p 2667k , vp9, 25fps, video only, 59.26MiB
    137          mp4        1920x1080  1080p 4331k , avc1.640028, 25fps, video only, 74.05MiB
    398          mp4        1280x720   720p 4689k , av01.0.05M.08, 25fps, video only, 39.76MiB
    399          mp4        1920x1080  1080p 8550k , av01.0.08M.08, 25fps, video only, 69.91MiB
    18           mp4        640x360    medium  645k , avc1.42001E, mp4a.40.2@ 96k (44100Hz), 17.30MiB (best)
    Mar 2008
    I would have thought so, the version I downloaded was obtained using youtube-dl with no operands except the URL
    Video
    Format                                   : AV1
    Format/Info                              : AOMedia Video 1
    Format profile                           : Main@L4.0
    Codec ID                                 : V_AV1
  7. Thank you, guys.
    Problem solved!
    Yes, GomPlayer can use directshow codecs and I got davexnet's suggestion about LAV filters.
    Nice to see you both, still here, after many years.
    Cheers.
    [Attachment 49968 - Click to enlarge]
    Thank you.
    Apr 2021
    Dallas TX
    I still have this same problem. I am a newbie and am confused by the supposed solution to this problem. I followed the links and think I have correctly located and installed the suggested codecs. But I guess I don't know how to get my old GOM Player (v.2.1.5) to utilize them and play the video (audio is fine) of the av1/AOM files I download. I can play them with other players I have but my preferred player is still the old GOM Player. Any help would be greatly appreciated.
  9. Ted Smith, sorry for a long delay to answer your question.
    But I was away from my registered e-mail here and, just today I could read your post.
    First, you have to install LAV filters.
    After that, open GOM Player and go to settings (F5).
    My language is Portuguese, but I guess you'll find the right places to change.
    At section "Filters" and at fist tab, uncheck your video extension.
    [Attachment 62540 - Click to enlarge]
    In example above, I unchecked MKV files.
    Close GOM and open it again. I think, you'll get your video openning.
    Thank you.
