Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
    Nov 2015
    Campuchia - Sapoche
    Problem solved. Thanks all for your help .
  2. old question but now server have changed the rules, and now trick at post #30 not work...
    link: https://tv24.vn/chi-tiet/21553/phap-vong-truy-kich/1
    login --- 0784412680 | 0784412680A
  3. Originally Posted by lomero View Post
    interesting challenge, open to all!
    - summary data -
    login --- 0784412680 | 0784412680A or 0909445425 | 0909445425A
    I have looked into it for the past few days and the best i managed to do is downloading 260 .ts files but with errors maybe if i can merge them together it will give the video but i dont think you will get a picture since they are DRM protected
  6. where put value of post #25 on streamlink?
    Nov 2015
    Campuchia - Sapoche
    i try few month but not work, in the future if you find a solution please do let me know, thanks for your help.
  8. Traceback (most recent call last):
    File "threading.py", line 916, in _bootstrap_inner
    File "C:\Users\WATCH01\Downloads\streamlink-portable-1.7.0-py3.6.5-amd64\streamlink\packages\streamlink\stream\segmented.py", line 190, in run
    self.write(segment, result)
    File "C:\Users\WATCH01\Downloads\streamlink-portable-1.7.0-py3.6.5-amd64\streamlink\packages\streamlink\stream\hls.py ", line 141, in write
    sequence.num)
    File "C:\Users\WATCH01\Downloads\streamlink-portable-1.7.0-py3.6.5-amd64\streamlink\packages\streamlink\stream\hls.py ", line 95, in create_decryptor
    return AES.new(self.key_data, AES.MODE_CBC, iv)
    File "C:\Users\WATCH01\Downloads\streamlink-portable-1.7.0-py3.6.5-amd64\streamlink\packages\Crypto\Cipher\AES.py", line 260, in new
    return _create_cipher(sys.modules[__name__], key, mode, *args, **kwargs)
    File "C:\Users\WATCH01\Downloads\streamlink-portable-1.7.0-py3.6.5-amd64\streamlink\packages\Crypto\Cipher\__init__.p y", line 130, in _create_cipher
    return modes[mode](factory, **kwargs)
    File "C:\Users\WATCH01\Downloads\streamlink-portable-1.7.0-py3.6.5-amd64\streamlink\packages\Crypto\Cipher\_mode_cbc. py", line 232, in _create_cbc_cipher
    cipher_state = factory._create_base_cipher(kwargs)
    File "C:\Users\WATCH01\Downloads\streamlink-portable-1.7.0-py3.6.5-amd64\streamlink\packages\Crypto\Cipher\AES.py", line 130, in _create_base_cipher
    raise ValueError("Incorrect AES key length (%d bytes)" % len(key))
    ValueError: Incorrect AES key length (20 bytes)
    i can't download link , you may help me
