Results 1 to 30 of 39
    Nov 2015
    Campuchia - Sapoche
    Problem solved. Thanks for all
    Nov 2015
    Campuchia - Sapoche
    Originally Posted by LZAA View Post
    Need access.
    update account login this site, plese help me .
  3. Which account?
    Nov 2015
    Campuchia - Sapoche
    Which account?
    Account Login
    Nov 2015
    Campuchia - Sapoche
    How did you succeed and please help give me code for streamlink, livestream, ffmpeg get the video ? thank you .
  6. Streamlink appears to work with referer, user agent, etc:
    streamlink --http-header "User-Agent=Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:68.0) Gecko/20100101 Firefox/68.0" --http-header streamlink --http-header "User-Agent=Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:68.0) Gecko/20100101 Firefox/68.0" --http-header "Referer=https://tv24.vn/chi-tiet/24425/ky-an-nha-thanh-phan-2/1" -o "playlist.ts" "https://drm-web.tv24.vn/vod_sctv_drm/_definst_/cache/vod3/FileConverted2016/nhomyoutube/HD/phimbo/TVB/kyannhathanhp2/kyannhathanhp201/smil:kyannhathanhp201_1398fic2906.smil/playlist.m3u8?uid=w2948444y2a474z584x506&t_end=o4i5u5h5144413a40324a4u2x2y2t2&p_form=r4i5i5x5o45403&otttokenstarttime=1567182523&otttokenendtime=1567190023&otttokenhash=Ow2tVl7cs7_Kg0-wJ-IWOfvI9wQi_9xXbZxJ0WY2tK0=" best
    You may need to get fresh values. I use Firefox with "The Stream Detector" plugin to get the full streamlink command line.
    Nov 2015
    Campuchia - Sapoche
    Dear jagabo, i can using your streamlink code to download succeed, Big thanks u again .
    Dear Mode, it's done, please help me to delete this thread, thank you .
    Nov 2015
    Campuchia - Sapoche
    Hi jagabo, i get problem today, please help me again, thanks .
  9. Code:
    streamlink-portable-1.1.1-py3.6.5-amd64\streamlink>streamlink --http-header "User-Agent=Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:68.0) Gecko/20100101 Firefox/68.0" --http-header "Referer=https://tv24.vn/chi-tiet/24425/ky-an-nha-thanh-phan-2/1" -o "playlist.ts" "https://drm-web.tv24.vn/vod_sctv_drm/_definst_/cache/vod3/FileConverted2016/nhomyoutube/HD/phimbo/TVB/kyannhathanhp2/kyannhathanhp201/smil:kyannhathanhp201_1398fic2906.smil/playlist.m3u8?uid=w2948444y2a474z584x506&t_end=o4i5u5h5144413a40324a4u2x2y2t2&p_form=r4i5i5x5o45403&otttokenstarttime=1567182523&otttokenendtime=1567190023&otttokenhash=Ow2tVl7cs7_Kg0-wJ-IWOfvI9wQi_9xXbZxJ0WY2tK0=" best
    [cli][info] Found matching plugin hls for URL https://drm-web.tv24.vn/vod_sctv_drm/_definst_/cache/vod3/FileConverted2016/nhomyoutube/HD/phimbo/TVB/kyannhathanhp2/kyannhathanhp201/smil:kyannhathanhp201_1398fic2906.smil/playlist.m3u8?uid=w2948444y2a474z584x506&t_end=o4i5u5h5144413a40324a4u2x2y2t2&p_form=r4i5i5x5o45403&otttokenstarttime=1567182523&otttokenendtime=1567190023&otttokenhash=Ow2tVl7cs7_Kg0-wJ-IWOfvI9wQi_9xXbZxJ0WY2tK0=
    [cli][info] Available streams: 480p (worst), 576p, 720p, 1080p (best)
    [cli][info] Opening stream: 1080p (hls)
    [download][playlist.ts] Written 4.9 MB (13s @ 374.3 KB/s)
    Nov 2015
    Campuchia - Sapoche
    you copy this link for jagabo, you can give me this proof ?
    someone help me please .
  11. Originally Posted by therain View Post
    I wasn't able to download that video. I get an AES key length error -- same as you.
    Nov 2015
    Campuchia - Sapoche
    Thanks for your help .
    is anyone have an idea how to download *.m3u8 playlists with AES key, please help because it hard to me .
    Nov 2015
    Campuchia - Sapoche
    It's ok now, im using new command for streamlink to download, thanks for your help .
  14. Originally Posted by therain View Post
    What is it?
    Nov 2015
    Campuchia - Sapoche
    What is it?
    Im sent you PM .
  16. Originally Posted by therain View Post
    What is it?
    Im sent you PM .
    The point is to help other people who may be reading this thread, now and in the future. There's no personal information in your PM. So there's no reason not to post the solution here.
    Nov 2015
    Campuchia - Sapoche
    thanks for your idea, my information has been updated and next time, i will post the solution to do that .
  18. Member
    Nov 2015
    Campuchia - Sapoche
    This worked well till November 12, 2019 and this server has been fixed now .
    URL --> https://tv24.vn/chi-tiet/21552/khong-khoan-nhuong/2
    Account login --->
    Some firefox plugins used to work but not anymore. It uses AES-128 decryption and i've tried various methods,but nothing so far.
    Plugin gives .m3u8 url,but it's unplayable.
    I've tried streamlink and youtube-dl so far. Closest i got was with streamlink and youtube-dl,but got error:
    File "C:\Program Files (x86)\Streamlink 1.2.0\pkgs\streamlink\stream\hls.py",
    line 124, in write
    sequence.num)
    line 80, in create_decryptor
    return AES.new(self.key_data, AES.MODE_CBC, iv)
    File "C:\Program Files (x86)\Streamlink 1.2.0\pkgs\Crypto\Cipher\AES.py", line
    202, in new
    return _create_cipher(sys.modules[__name__], key, mode, *args, **kwargs)
    File "C:\Program Files (x86)\Streamlink 1.2.0\pkgs\Crypto\Cipher\__init__.py",
    line 79, in _create_cipher
    return modes[mode](factory, **kwargs)
    File "C:\Program Files (x86)\Streamlink 1.2.0\pkgs\Crypto\Cipher\_mode_cbc.py"
    , line 234, in _create_cbc_cipher
    cipher_state = factory._create_base_cipher(kwargs)
    92, in _create_base_cipher
    raise ValueError("Incorrect AES key length (%d bytes)" % len(key))
    ValueError: Incorrect AES key length (0 bytes)
    [hls @ 00000000004ca100] Skip ('#EXT-X-VERSION:3')
    [hls @ 00000000004ca100] Opening 'https://vtsstr4.tv24.vn:2126/licenseServer.php
    ?name=khongkhoannhuong02_4500_t26494a4y2a4x2c4v234 n4q5p5p503q5g4v5j4k5p5c4g484g4
    i4c4q4i4l4n5w2s244y5y2z2y2f4z2546466x2f5u2u4z2a494 q4347454&wowzasessionid=705485
    785&uid=x2946414r25474z584x50634o4c444o4q4v2v2&ott tokenstarttime=1575463950' for
    reading
    [hls @ 00000000004ca100] Unable to read key file https://vtsstr4.tv24.vn:2126/li
    censeServer.php?name=khongkhoannhuong02_4500_t2649 4a4y2a4x2c4v234n4q5p5p503q5g4v
    5j4k5p5c4g484g4i4c4q4i4l4n5w2s244y5y2z2y2f4z254646 6x2f5u2u4z2a494q4347454&wowzas
    essionid=705485785&uid=x2946414r25474z584x50634o4c 444o4q4v2v2&otttokenstarttime=
    1575463950
    Is there any way to download content from this site, could someone kindly suggests a solution ?
  19. Originally Posted by therain View Post
    This worked well till November 12, 2019 and this server has been fixed now ...
    I do not know but :
    Nov 2015
    Campuchia - Sapoche
    I do not know but :
    Hi sysanin
    Thanks for your reply.
    Can you tell me how to download with streamlink or youtube-dl ?
    Thank you !
  21. content from this site?
  22. Member
    Nov 2015
    Campuchia - Sapoche
    Yes, do you know how to download it with streamlink or youtube-dl ? help me please .
    I really hope i won't have to use a screen recorder for this.
  23. Member Emeritus
    May 2014
    As others have mentioned, at minimum the header values for EXT-X-UID, EXT-X-CID, EXT-X-TOKEN are required to obtain the aes key.
    However, it appears that web player does not use the key value returned from the license server literally, but rather only as a seed to calculate the actual aes key. Or independently calculate the IV.
    A solution to obtain the hls might require something like a custom streamlink plugin.
    Advise if you just need the one video from the url that you posted.
  25. Member
    Nov 2015
    Campuchia - Sapoche
    HI LZAA, thanks for your help, but i need more to download on this site .
    Can you explain me how to do it which another app using command line?
    Thanks so much .
  27. change playlist.m3u8 ====> manifest.f4m
