While extracting subtitles from an IFO using VSRip I, for some discs, get "bad packet header found" endlessly and no subtitle can be extracted. However, when I load that IFO+VOB in Handbrake, it has no problem retrieving the subtitle tracks. Why is this happening? Is there another tool (preferably with CLI) that can be used to extract IDX/SUB subtitles?
If you don't do NTSC field processing you can forget about VSRip and VobSub altogether and use MakeMKV and mkvextract instead, it's much easier and more reliable.
Adding Audio Description in PES Packet (via Manzanita)
By JamesFerhan in forum ProgrammingReplies: 0Last Post: 8th May 2019, 15:06 -
Issue extracting subtitles from DVD with VSRip
By Vitality in forum SubtitleReplies: 3Last Post: 17th Oct 2018, 15:00 -
Multiple frames in a packet ac-3 FFMEG conversion error!
By Anonymous5394 in forum Video ConversionReplies: 0Last Post: 30th Sep 2018, 05:48 -
Bad Drive or failing controller ?
By DB83 in forum ComputerReplies: 28Last Post: 24th Oct 2016, 10:17 -
TSPE (transport stream packet editor) issues!
By raptor1015 in forum Capturing and VCRReplies: 1Last Post: 6th Feb 2016, 02:49
