I seem to be having an unusual error. I'm using a AIW Radeon and W2k (NTFS). I just upgraded (after uninstall) to the latest video driver, video capture driver, and MMC 7.6. When capturing large files, and by large I mean over 4gb significantly enough, I get an error when I save the file. It says: "(RManager) An Unknown error occured while accessing an unnamed file." The file is saved, but it is unscannable and tends to crash all viewers. I didn't have this problem before with earlier versions and I don't have the problem with capturing large AVI files in VDub.
Any ideas?
Well,
I had a 'sort of similar' problem with a NTFS drive where the data would not accept a file name, but the file was there. I reformatted the drive (which Win2k did not like btw) because it was new and nearly empty. However, I believe that running error correction (chkdsk) and defragmenting the drive should be all that's needed. Be prepared for the defragement to take a while. Also, I was running Norton Utilities, which keeps a record of files (especially big ones which are noticeable).
Good Luck!
Stan -
Well,
Good Luck!
Stan -
Under XP pro, I get this error every time but the files are always usable. Some progs have problems with over 4GB files, are you sure your viewers will handle them?
OK, I tried out another file, and it does seem to be player dependent. I couldn't find an actual player that crashed this time, but it seemed to before. My drive is defragged often, so I doubt that was a problem. I still have problems with flask/xmpeg opening the file, but that does seem to be a 4gb problem.
Thanks for the help.
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 10:13 -
Easycap usb large capture files
By visionman in forum Capturing and VCRReplies: 5Last Post: 4th May 2010, 17:23 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
(Completed): MMC capture results in 44100 sample freq instead of 48000.
By palouse in forum Capturing and VCRReplies: 14Last Post: 23rd Oct 2007, 15:47 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
