  1. I've tested some out in the preview screen and it's quite hard to pick which does the best job.
    Is there one which is specially good?
    I have two videos I need it for. One which only needs a tiny bit of anti-aliasing. Then there is one which has a lot of uneven edges and is in desperate need for a strong aliasing filter.
  2. There is no "best" .
    You have to try different ones, different settings - because what is "ideal" for one video, might not be ideal for another .
    For example, you wouldn't use the same filter or settings for the video that needs a "tiny bit" compared to the one that needs a strong filter
    It also depends if there is a temporal component or not (shimmering between frames); many filters are spatial only
    And there might be better options you can use through an avs script that you can import into staxrip
