Sometimes I get on startup "UEFI defaults have been loaded, press F2 to enter setup or F1 to continue." I have an Asrock motherboard, and at https://forums.tomshardware.com/threads/uefi-defaults-have-been-loaded.2754234/ I found 2 other users with Asrock motherboard having the same problem. Does anyone know cause of or fix for this problem, and do you think this may be a fault or failure associated with Astock motherboards?
i've had good luck with asrock motherboards in general. if i had one that wouldn't keep it's bios settings the first thing i would try is replacing the cmos battery. usually a "2032" flat cell watch type on the motherboard.
What Aedipuss said. Then I'd check the voltages from the power supply - it's surprising how many issues stem from overly cheap or failing power supplies.
I replaced the battery with new one and so far so good, but I won't know for sure for few days whether the problem may continue. However, I suspect the motherboard may have gone bad. I didn't mention it before, but when the BIOS resetting problem occurred, I also had problems with hard drives being recognized in both the BIOS and in Windows resulting in startup problems. The only way I could get drives correctly recognized was to try different sata ports. This problem in addition to the BIOS reset problem supports the conclusion that it's likely a bad motherboard I think.
There have been no more BIOS resets or hard drive recognition issues since new battery was installed. It appears a bad battery may have been the cause of both problems, and I’ll post back here if the problems recur.
There’s 1 other small problem I noticed for Internet Explorer 11 in Win10. According to several searches I did right click at top o IE11 and place check by “Show tabs on a separate line” is supposed to result in a search box appearing to the riightt of the address window. However, this results in no search box showing in my IE11. Does anyone know anything about this problem or know how to fix it? It’s no big problem since I use Firefox for most browsing and use IE only when required by certain sites, but it’s perplexing why my IE11 doesn’t behave like it should. -
batch that check if a video file is loaded whith a specific DS decompressor
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2018, 11:45 -
[GOM Player] How can I make GOM Player open every video with same defaults
By czerwinski76 in forum Newbie / General discussionsReplies: 0Last Post: 5th Feb 2017, 12:52 -
Issues with HV40.... Not sure where to go from here.
By ducksalot in forum Capturing and VCRReplies: 15Last Post: 10th Oct 2016, 00:29 -
Keep getting libfftw3f-3.dll could not be loaded error.
By Nagashi in forum Video ConversionReplies: 4Last Post: 13th Jul 2016, 16:16 -
MPC always defaults to English subtitles
By Starbuck1991 in forum SubtitleReplies: 1Last Post: 10th Apr 2016, 14:08
