What could cause that the picture is awfully pixelated when transfering from mini-DV to a win 7 computer through firewire? Not just a little, but so that you cannot see what's on the picture? The picture looks fine on the lcd screen on the camcorder and when capturing through s-video.
I've tried two different Firewire cables.
BR Peter.
The picture being clear in the camera's viewfinder suggests it is not dirty heads or a bad tape. Likely candidates are a bad or loose firewire connector in the camera, a bad or loose firewire connector in the computer, a bad firewire cable (which you also have eliminated,) or some sort of software/driver issue. As you no doubt know, the way to trouble shoot this is to replace each possible problem systematically until you determine what's wrong.
Have you tried this capture software?
https://www.videohelp.com/software/WinDV -
Does it do it consistently, ie. for the whole tape and also other tapes?
Thanks everybody for your help. This evening I re-connected it - and it works just perfectly! I almost can't believe my eyes. It's amazing to see this quality when transferring the digital files directly from tape to computer.
I don't know what caused the problem, but now it's gone!
Thanks again!
Issues With Capturing From Mini DV Camcorder
By escobar45 in forum Capturing and VCRReplies: 6Last Post: 24th Aug 2019, 19:54 -
Capturing VHSC via AV to DV out to mini fire wire
By Jim2015 in forum Capturing and VCRReplies: 2Last Post: 19th Nov 2015, 18:34 -
I am considering capturing via FireWire
By Hypersonic1 in forum Capturing and VCRReplies: 70Last Post: 30th Aug 2015, 10:04 -
Capturing from mini DV
By garret2015 in forum Capturing and VCRReplies: 9Last Post: 1st Dec 2014, 22:28 -
capturing mini-dv footage using iMovie11
By zoranb in forum Capturing and VCRReplies: 12Last Post: 7th Sep 2014, 14:41
