    Apr 2018
    Sunsari [Nepal]
    I have some old movies and i want to add sharpness while encoding video in megui, How i can add sharpness on that videos while encoding,
    please Help me with detailed guide,
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Avisynth has a simple Sharpen() function built in. Sharpen(0.1) for light sharpening or Sharpen(1) for the highest. Other external sharpeners can also be used like at http://avisynth.nl/index.php/External_filters#Sharpeners
    Apr 2018
    Sunsari [Nepal]
    Will you please tell me how to use external sharpen filters, in me gui, i have no idea about using external plugin
    Mar 2008
    Start MeGui.
    Tools / AVS script creator /config
    presets / new (give it a name) add "sharpen(0.3)in the script body/Update/OK out/close AVS script editor
    One click encoder/load your source/Output config/
    Video tab/Avisynth Setup / Profile (select the script you created in the first step)/OK out
    Queue to run your job
