I still can't believe that there's not an app out there that will capture screenshots of Blu-ray menus. You can decrypt and rip the whole shebang. You can even edit the menu like I did with The Black Hole today, because Disney are idiots.
BUT....
I can't take a screenshot of the menu in it's entirety with the buttons and text. I was told that Arcsoft TotalMedia Theatre 3 is able to do this, but I can't find anything older than version 5.
Can someone please help?
Results 1 to 18 of 18
try the tips here - https://forum.videohelp.com/threads/366519-Blu-ray-screenshots-without-ripping
Video is normally in overlay mode, and you can't screencap it.
It must be opened in something that allows screencaps in this mode. VLC is one potential method.Want my help? Ask here! (not via PM!)
Indeed. Already tried, but thanks.
**EDIT** Using VLC with a brand-new install of Java helped with one of the titles, so thanks for the extra push I needed to try it. It's not a 100% solution, but it's a start.Last edited by User897; 25th Aug 2019 at 02:45.
Thanks. Also, in the Blu-ray tab, uncheck the "No menus" checkbox if you want to try going after menu screenshots. Then press Alt-Print Screen and paste into Paint Or Photoshop or whatever. If it asks to resample the image, it's best to choose No.
That's all well and good, but I still am going to continue my search for Arcsoft TotalMedia Theatre 3. Unless a new option comes along. -
No, I don't think so. TMT installs a driver of some sort that is incompatible with Windows 10. I had TMT6 and it caused problems constantly, eventually leading to instability.
I'm pretty sure TMT3 won't even install in Windows 10, but I'm not willing to experiment. A Windows XP virtual machine is probably the best bet.Last edited by Kerry56; 28th Aug 2019 at 20:19.
Oh crap, I didn't even think about that. I think the last system it was on was XP. Oh dear.
I got the software, but of course it won't run on Windows 10. It installed, but won't open. I wanted to use Sandboxie, but my computer won't even let me install it, stating that it is dangerous. I used it on my last Windows 10 machine. I know I need a VM, but not sure at all where to get one.
Does TMT3 run if you disable Data Execution Prevention for the EXE? I have a .reg file in my TMT3 installer folder with a note I wrote saying that BD-J menus crash due to DEP. I think this was on Win7. Maybe Win10's additional protections prevent running altogether. Or maybe the video subsystem in Win10 really is too different for it to work.
https://www.virtualbox.org/ is free, if you choose to pursue the VM option.
I hope you don't need pixel-perfect captures. I'm not 100‰ sure about the menus, but for its Screenshot function in general, TMT3 degrades the image, apparently by design. -
Thanks for the input! I've decided to abandon this ill-fated attempt, but I am saving everything just in case I want to try again in the future.
Is there a way to take a screencap of a blu-ray menu?
By Hatteras in forum Newbie / General discussionsReplies: 5Last Post: 4th Feb 2018, 20:30 -
Is there a good external blu-ray burner?Any ray of hope?
By navarannan in forum DVD & Blu-ray WritersReplies: 36Last Post: 21st Sep 2016, 05:28 -
trying to burn A New Hope Despecialized Edition to blu ray
By puffpants in forum Newbie / General discussionsReplies: 11Last Post: 26th Dec 2015, 20:46 -
Edit/add to blu ray menu
By adzyu100 in forum EditingReplies: 4Last Post: 25th Jan 2015, 10:24 -
Blu-ray screenshots without ripping
By scarecroe in forum Blu-ray RippingReplies: 6Last Post: 12th Sep 2014, 16:40
