For me, Chrome won't download files large than 2 GB. What can be done to solve this problem?
Results 1 to 11 of 11
Have you tried another browser? this would isolate it to a browser problem or website.
Stream Video Downloader, for Chrome, is the only thing that will work for some sites. If the download is larger than 2 GB, it is corrupted.
So, again, what are you downloading these files to storage wise ? And what is the format of it FAT, FAT16, FAT32, NTFS etc. ?
I'm not sure why you are asking this question in this forum. A simple Google search turns up lots of answers. Most seem to recommend using a plugin (or addin, or whatever Chrome calls them) that is specifically designed for downloads.
^^ Well the OP is actually using an addin >> Reply #4
Maybe the addin has a download limit and these downloaders are typically just for short clips. 'Large >> 2 gb files suggest movies and HD at that.
Maybe I also misjudge and the OP has the right to download but he should also read the forum rules about 'rentals' and if that is the case then help ends here. -
"Programmers are human-shaped machines that transform alcohol into bugs."
If you check the Chrome website (reviews) there are others that are having the same problem with 2gig files with this add-in, so dump it and get something else.
Google Chrome - How to Download / Install Add-ons Manually?
By devilcoelhodog in forum ComputerReplies: 4Last Post: 20th Nov 2017, 18:28 -
Strange case with m3u8 in chrome - stream won't playback
By interman_1 in forum Video Streaming DownloadingReplies: 0Last Post: 12th Oct 2016, 16:45 -
Chrome DRM Bug Makes It Easy To Download Streaming Video
By zzfredzz in forum Video Streaming DownloadingReplies: 0Last Post: 10th Aug 2016, 09:31 -
Tampermonkey - For Chrome Browser - Where to Download the Addon Itself?
By devilcoelhodog in forum ComputerReplies: 0Last Post: 4th Aug 2016, 21:19 -
Why won't movie play in Chrome?
By jgg in forum Newbie / General discussionsReplies: 9Last Post: 19th Sep 2015, 04:16
