I would like to ask how to move 2nd line to 1st lines time, then 3rd line to 2nds line time and do this for all subtitles? (1st line would go to new manually created 1st line) You can see image bellow. Would be nice to do this in Subtitle Edit. Thank you
[Attachment 49895 - Click to enlarge]
(Create new first line.) Right-click the first line->"Column"->"Delete text and shift cells up"
Anyone know of a sub program that will break long lines into 3 lines?
By JeremyBrown in forum SubtitleReplies: 19Last Post: 13th Apr 2020, 19:03 -
Is there a way i can re-time all the lines in a subtitle file at once?
By Unknown01 in forum Newbie / General discussionsReplies: 5Last Post: 10th Apr 2020, 12:35 -
Make a 'hot key' for 'Duplicating' lines in Aegisub
By Kinderzoo in forum SubtitleReplies: 2Last Post: 14th May 2019, 06:19 -
How can I remove these lines?
By killerteengohan in forum RestorationReplies: 15Last Post: 16th Mar 2015, 04:19 -
DVDR with Lines on Top and Lines on Bottom?
By Disco Makberto in forum MediaReplies: 13Last Post: 14th Feb 2015, 03:34
