  1. Hi,
    I updated Potplayer from an older version I was using 1.6.xxx to the latest 1.7.xxx and the first thing that I noticed is that I'm having "staircase effect" artifact. I tried lot's of different options but it only goes away if I disable the VLD bitstream decoding, whatever that means. But I can't have it disabled because FHD HEVC videos are using too much CPU otherwise, so I need to find a workaround this.
    Can anyone help out fellow moviephile ? Don't hesitate if you need any other information.
    Thank you for reading. Kind regards.
  2. I solved my problem by switching to OpenGL renderer.
