Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 79
  1. Member hydra3333's Avatar
    Oct 2009
    Australia
    Ah. Unfortunately this seems to result in a file with dropped HDR info:
    "NVEncC64.exe" --avsw -i "HDR-HEVC-TEST.ts" -o "HDR-HEVC-TEST.ts.nvencc.hevc.mp4" --output-depth 10 --preset quality --vbrhq 0 --vbr-quality 0 --lookahead 32 --aq --aq-temporal --aq-strength 0 --mv-precision q-pel --profile main10 --level 6 --tier high --chapter-copy --sub-copy --data-copy --audio-copy
    I couldn't find any examples for usage of the option "--dhdr10-info <string>"
  2. Banned
    Feb 2013
    Sample
    "C:\Program Files (Portable)\NVEncC\NVEncC64.exe" --vbrhq 38400 --codec h265 --preset quality --profile main10 --level 5.1 --output-depth 10 --ref 5 --gop-len 24 --lookahead 32 --qp-init 1 --max-bitrate 38400 --vbr-quality 25 --aq --cuda-schedule auto --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635, 16450)L(10000000,1)" --colormatrix bt2020nc --colorprim bt2020 --transfer smpte2084 --max-cll "1351,384" --aud --mv-precision q-pel --cabac -i T:\SHAZAM_temp\xxx.vpy -o T:\xxx_temp\xxx_out.h265
    Your video card is also capable of b frames
  3. Member hydra3333's Avatar
    Oct 2009
    Australia
    Thank you!
    I had done some small experiments last year with obtaining source settings via ffprobe and mediainfo and re-applying them on a commandline as you kindly showed.
    I was interested to learn more recently that nvencc and ffmpeg, using nvidia's nvenc, also omit things apparently called SEI messages et al which I gather may contain dynamic hdr10 related metadata or something like that.
    I note there is some scheme to obtain that data from the source (not certain, along something along the lines of piping ffmpeg generated raw stream to a metadata extractor and saving the result as a file) and then somehow re-apply that extracted into into the transcoded file. Issues apparently arise if re-sizing or other filtering (perhaps not when more strongly compressing?), so it's not perfect. AFAIK Neither ffmpeg nor nvencc do this automatically, and neither (AFAIK) do they pass through the HDR settings as you showed in the commandline.
    A question could also be, if you can't filter or re-size then why not just copy the source file as-is or copy streams to another container if that's the reason for this (assuming the rest of the HDR metadata comes with a copy).
    I'd hoped to be corrected, and maybe someone could show the sequence of commandlines for the process of dealing with the SEI stuff
  4. Banned
    Feb 2013
    If by pass thru the HDR you mean does it show up in the final output?
    The answer is yes, I usually use MKV container and when I use NVEncC the final result retains the HDR metadata and it makes my tv switch to HDR mode automatically.
    Many, many moons ago I did have to use hdr patcher to implant the metadata but that was long ago in a galaxy far away
  5. Banned
    Feb 2013
    Use the -h option (help) on NVEncC64 (32)
    avs /vpy input is allowed
    Use a script for preprocessing if you wish, best of both worlds
    See options for cropping and resizing
    When I use NVEncC I use a vpy script with all the pre processing and let NVEncC encode, no extra stuff
  6. Member hydra3333's Avatar
    Oct 2009
    Australia
    Ah, I may try with mkv.
    This log shows it doesn't seem to work for me
    "C:\SOFTWARE\NVEncC\NVEncC64.exe" --avsw -i "HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts" -o "HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts.nvencc.hevc.mp4" --output-depth 10 --preset quality --vbrhq 0 --vbr-quality 0 --lookahead 32 --aq --aq-temporal --aq-strength 0 --mv-precision q-pel --profile main10 --level 6 --tier high --videoformat pal --chapter-copy --sub-copy --data-copy --audio-copy
    avsw: --sub-copy is set, but no subtitle stream found.
    NVEncC (x64) 4.45 (r1169) by rigaya, Aug 19 2019 11:47:02 (VC 1916/Win/avx2)
    OS Version     Windows 10 x64 (18362)
    CPU            AMD Ryzen 9 3900X 12-Core Processor (12C/24T)
    GPU            #0: GeForce RTX 2060 SUPER (2176 cores, 1665 MHz)[PCIe3x16][436.2]
    NVENC / CUDA   NVENC API 9.0, CUDA 10.1, schedule mode: auto
    Input Buffers  CUDA, 44 frames
    Input Info     avsw: hevc(yv12(10bit))->p010 [AVX2], 3840x2160, 60000/1001 fps
    Vpp Filters    copyHtoD
    Output Info    H.265/HEVC main10 @ Level unknown
                   3840x2160p 1:1 59.940fps (60000/1001fps)
                   avwriter: hevc, aac => mp4
    Encoder Preset quality
    Rate Control   VBRHQ
    Bitrate        0 kbps (Max: 230400 kbps)
    Target Quality auto
    Initial QP     I:20  P:23  B:25
    VBV buf size   auto
    Lookahead      on, 32 frames, Adaptive I, B Insert
    GOP length     600 frames
    B frames       3 frames [ref mode: disabled]
    Ref frames     3 frames, LTR: off
    AQ             on
    CU max / min   auto / auto
    Others         mv:Q-pel pic-struct
    [1.6%] 59 frames: 29.93 fps, 39185 kb/s, remain 0:02:05, GPU 23%, VE 73%
    [100.0%] 11785 frames: 62.98 fps, 103368 kb/s, remain 0:00:00, GPU 25%, VE 82%
    encoded 11849 frames, 62.42 fps, 102810.24 kbps, 2422.76 MB
    encode time 0:03:09, CPU: 34.7, GPU: 26.0, VE: 91.0, GPUClock: 1948MHz, VEClock: 1798MHz
    frame type IDR   54
    frame type I     54,  avgQP  9.33,  total size    48.30 MB
    frame type P   4486,  avgQP  9.76,  total size  1393.87 MB
    frame type B   7309,  avgQP  11.73,  total size   980.60 MB
    Source with HDR:
    Mon 26/08/2019 16:50:36.22 "C:\software\mediainfo\mediainfo.exe" "HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts"
    General
    Complete name                            : HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts
    Format                                   : MPEG-TS
    File size                                : 1.20 GiB
    Duration                                 : 3 min 18 s
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 51.8 Mb/s
    Video
    Menu ID                                  : 1 (0x1)
    Format                                   : HEVC
    Format/Info                              : High Efficiency Video Coding
    Format profile                           : Main 10@L5.1@High
    HDR format                               : SMPTE ST 2086, HDR10 compatible
    Codec ID                                 : 36
    Duration                                 : 3 min 17 s
    Width                                    : 3 840 pixels
    Height                                   : 2 160 pixels
    Frame rate                               : 59.940 (60000/1001) FPS
    Bit depth                                : 10 bits
    Writing library                          : ATEME Titan File 3.7.9 (4.7.9.0)
    Color range                              : Limited
    Color primaries                          : BT.2020
    Transfer characteristics                 : PQ
    Matrix coefficients                      : BT.2020 non-constant
    Mastering display color primaries        : Display P3
    Mastering display luminance              : min: 0.0500 cd/m2, max: 1000 cd/m2
    Audio
    Menu ID                                  : 1 (0x1)
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Format version                           : Version 4
    Muxing mode                              : ADTS
    Codec ID                                 : 15-2
    Bit rate mode                            : Variable
    Channel(s)                               : 6 channels
    Channel layout                           : C L R Ls Rs LFE
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Result without HDR
    Mon 26/08/2019 16:50:36.71 "C:\software\mediainfo\mediainfo.exe" "HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts.nvencc.hevc.mp4"
    General
    Complete name                            : HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts.nvencc.hevc.mp4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (isom/iso2/mp41)
    File size                                : 2.38 GiB
    Overall bit rate                         : 103 Mb/s
    Writing application                      : NVEncC (x64) 4.45
    Video
    Format                                   : HEVC
    Format profile                           : Main 10@L6@High
    Codec ID                                 : hev1
    Codec ID/Info                            : High Efficiency Video Coding
    Bit rate                                 : 103 Mb/s
    Frame rate mode                          : Constant
    Standard                                 : PAL
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.207
    Stream size                              : 2.37 GiB (100%)
    Codec configuration box                  : hvcC
    Audio
    Format                                   : AAC LC
    Codec ID                                 : mp4a-40-2
    Bit rate mode                            : Constant
    Bit rate                                 : 384 kb/s
    Stream size                              : 8.99 MiB (0%)
    Default                                  : Yes
    Alternate group                          : 1
    Mon 26/08/2019 16:50:36.75
    Mon 26/08/2019 16:50:36.76 --------------------------------------------------------------------------------------------
    Mon 26/08/2019 16:50:36.76 C:\SOFTWARE\ffmpeg\0-homebuilt-x64\ffprobe.exe -i "HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts.nvencc.hevc.mp4" -show_format -hide_banner -show_streams
    [STREAM]
    index=0
    codec_name=hevc
    codec_long_name=H.265 / HEVC (High Efficiency Video Coding)
    profile=Main 10
    codec_type=video
    codec_time_base=1001/60000
    codec_tag_string=hev1
    codec_tag=0x31766568
    width=3840
    height=2160
    coded_width=3840
    coded_height=2176
    has_b_frames=1
    sample_aspect_ratio=1:1
    display_aspect_ratio=16:9
    pix_fmt=yuv420p10le
    level=180
    color_range=tv
    color_space=unknown
    color_transfer=unknown
    color_primaries=unknown
    chroma_location=unspecified
    field_order=progressive
    timecode=N/A
    refs=1
    id=N/A
    r_frame_rate=60000/1001
    avg_frame_rate=60000/1001
    time_base=1/240000
    start_pts=0
    start_time=0.000000
    duration_ts=47443396
    duration=197.680817
    bit_rate=102810244
    max_bit_rate=N/A
    bits_per_raw_sample=N/A
    nb_frames=11849
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:default=1
    DISPOSITION:dub=0
    DISPOSITION:original=0
    DISPOSITION:comment=0
    DISPOSITION:lyrics=0
    DISPOSITION:karaoke=0
    DISPOSITION:forced=0
    DISPOSITION:hearing_impaired=0
    DISPOSITION:visual_impaired=0
    DISPOSITION:clean_effects=0
    DISPOSITION:attached_pic=0
    DISPOSITION:timed_thumbnails=0
    TAG:language=und
    TAG:handler_name=VideoHandler
    [/STREAM]
    [STREAM]
    index=1
    codec_name=aac
    codec_long_name=AAC (Advanced Audio Coding)
    profile=LC
    codec_type=audio
    codec_time_base=1/48000
    codec_tag_string=mp4a
    codec_tag=0x6134706d
    sample_fmt=fltp
    sample_rate=48000
    channels=6
    channel_layout=5.1
    bits_per_sample=0
    id=N/A
    r_frame_rate=0/0
    avg_frame_rate=0/0
    time_base=1/48000
    start_pts=0
    start_time=0.000000
    duration_ts=9489408
    duration=197.696000
    bit_rate=381375
    max_bit_rate=382500
    nb_frames=9267
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:dub=0
    TAG:language=und
    TAG:handler_name=SoundHandler
    [/STREAM]
    [FORMAT]
    filename=HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts.nvencc.hevc.mp4
    nb_streams=2
    nb_programs=0
    format_name=mov,mp4,m4a,3gp,3g2,mj2
    format_long_name=QuickTime / MOV
    start_time=0.000000
    duration=197.696000
    size=2550149104
    bit_rate=103194767
    probe_score=100
    TAG:major_brand=mp42
    TAG:minor_version=512
    TAG:compatible_brands=isomiso2mp41
    TAG:encoder=NVEncC (x64) 4.45
    [/FORMAT]
    [aac @ 000001dc1267d280] This stream seems to incorrectly report its last channel as LFE[3], mapping to LFE[0]
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'HDR-HEVC-Samsung 4K HDR Demo - RedBull See the Unexpected.ts.nvencc.hevc.mp4':
      Metadata:
        major_brand     : mp42
        minor_version   : 512
        compatible_brands: isomiso2mp41
        encoder         : NVEncC (x64) 4.45
      Duration: 00:03:17.70, start: 0.000000, bitrate: 103194 kb/s
        Stream #0:0(und): Video: hevc (Main 10) (hev1 / 0x31766568), yuv420p10le(tv, progressive), 3840x2160 [SAR 1:1 DAR 16:9], 102810 kb/s, 59.94 fps, 59.94 tbr, 240k tbn, 59.94 tbc (default)
        Metadata:
          handler_name    : VideoHandler
        Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 381 kb/s (default)
        Metadata:
          handler_name    : SoundHandler
  7. Banned
    Feb 2013
    Nothing personal but I am going to get a little nasty (in order to help you)
    In your script where is the master display info, please look at my sample
    Why are you using PAL as the format (I realize you are in PAL land) >> UHD like BD has no PAL or NTSC
    enter the proper BT numbers, look at my sample
    Consider using a script
  8. Member hydra3333's Avatar
    Oct 2009
    Australia
    That's fair.
    Thankyou gonca.
    I had wondered that circa 1 minute before I saw your (good, fair) post.
    Cheers!
  9. Banned
    Feb 2013
    Here is a simple cheat system I use when in doubt
    Create the script with all your preprocessing
    Use a GUI like StaxRip to load your script and start the process
    Copy the command line
    Abort process and study the command line
    I know its tacky but it helps to figure things out
  10. Member hydra3333's Avatar
    Oct 2009
    Australia
    Thanks !
    I retried without the PAL bit, still no HDR info carried through into output. Oh well.
    I had an old roughy script to parse outputs of ffprobe and mediainfo and use those in commandline settings, and was hoping for something "better" possibly including processing of "SEI" type stuff which I'd seen a few posts about including over on ncencc's github issues list.
    OK, that's it from me.
  11. Banned
    Feb 2013
    Did you include (corrected for your clip)
    --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15 635, 16450)L(10000000,1)" --colormatrix bt2020nc --colorprim bt2020 --transfer smpte2084 --max-cll "1351,384"
    I know it works, I did over 100 UHD discs with NVEncC
    Try loading a script into StaxRip and see the command line it generates
  12. Member hydra3333's Avatar
    Oct 2009
    Australia
    apologies, I had cross-wires with you, ... I was testing to see if HDR metadata "auto passthrough" was a thing, which it isn't.
    manual command-line options/values are doable as you very correctly point out.
  13. Banned
    Feb 2013
    I still prefer to generate my own scripts and using that as input, so if I have to enter HDR metadata manually, so be it.
    Not the end of the world
  14. Member hydra3333's Avatar
    Oct 2009
    Australia
    I'm with you on that, especially given the current state of play.
  15. Member hydra3333's Avatar
    Oct 2009
    Australia
    Ah, to summarise the settings changes from various posts:
    1. just came across this: https://forum.doom9.org/showthread.php?p=1709584#post1709584
    madVR Options Explained
    2. Ensured 64-bit registration of the madVR .ax (for win10x64)
    3. Changed these madVR options:
    Chroma Scaling to Bilinear (processing done by GPU Texture Units)
    Image Downscaling to DXVA2 (processing done by GPU video logic)
    Image Upscaling to DXVA2
    under devices, properties, set "the native display bitdepth is" to "10 bit (or higher)"
    under devices, hdr, set "hdr" to "passthrough HDR to display"
    under devices, hdr, ensure ticked checkbox "send HDR metadata to the display"
    and the OSD changed to look like this:
    4. Changed these Win10x64 options:
    Display, Play HDR games and apps to On
    Display, Windows HD Colour Settings, Play HDR games and apps to On
    Display, Windows HD Colour Settings, Stream HDR Video to On
    And the resulting on-screen display changed to look like in this post:
    https://forum.videohelp.com/threads/394116-New-PC-pls-recommend-me-a-media-player-etc-...ck#post2558325
    bye.
  16. Hi,please help.I couldn't find,where can I change setting,
    Philips OLED 804,PC with AMD Ryzen 5 3400G.
    Thanks.
    Edit:I have it
  17. Member hydra3333's Avatar
    Oct 2009
    Australia
    Where was it ?
    Were you taking about a madvr setting or a Win10 setting ?
  18. I found it in madvr setting and shut down in windows.
  19. @hydra3333
    You may also want to try how the lean mpv player performs in your scenario.
    https://www.videohelp.com/software/mpv-media-player
  20. Member hydra3333's Avatar
    Oct 2009
    Australia
    Nice !
    Thank you.
  21. HDR works, but the picture is terribly dark, so pale,without colors.Some solution?Probably I'll watch without HDR...
  22. Member hydra3333's Avatar
    Oct 2009
    Australia
    Ah.
    How does this appear to you (watch all 2 mins) https://4kmedia.org/lg-chess-hdr-demo/
    (control J in MPC-HC to see stats including HDR and 10-bit)
    Or even this in Chrome browser https://www.youtube.com/watch?v=2RIDhA9c8qw
    (right click in the video area and choose stats for nerds)
    Both appear BEAUTIFUL on my rig, so perhaps consider double-checking your madvr and Win10 options ?
    ( hint https://forum.videohelp.com/threads/394116-New-PC-pls-recommend-me-a-media-player-etc-...ck#post2558325 and https://forum.doom9.org/showthread.php?p=1709584#post1709584 )
  23. Here is the screen. Is there something wrong?Do you see how gray and pale the picture is?
    http://screenshot.cz/WPE3G/
  24. Member hydra3333's Avatar
    Oct 2009
    Australia
    Can you please try the .mp4 from https://4kmedia.org/lg-chess-hdr-demo/ ?
    It is a known-good source. Particularly, the opening scene with the princess, does it get very colourful ?
    A screenshot would be great.
  25. Sorry, this file cannot be viewed or downloaded right now...
  26. Member hydra3333's Avatar
    Oct 2009
    Australia
    Hmmm, clicking on the "download file" button and then the "download anyway" button works every time here.
    Pls try again, so we know what a known good source looks like on your rig.
    Also, your madVR and Windows settings also reflect those in the attachment ?
Name:	Annotation 2019-09-09 165426.png
  27. Image
    [Attachment 51273 - Click to enlarge]
    [Attachment 51274 - Click to enlarge]
    Now the picture is much better,1.screen is without HDR on in Windows,2.with.What bothers me is that the picture is not good with my movies.
    e.g. Joker (2019)
    BDAV
    Formát/ : Blu-ray Video
    Velikost souboru : 51,4 GiB
    Duration/String : 2 h 1 min
    Celkový BitRate : 60,4 Mb/s
    OverallBitRate_Maximum/String : 109 Mb/s
    Video #1
    MenuID/String : 1 (0x1)
    Formát : HEVC
    Formát/ : High Efficiency Video Coding
    Format_Profile : Main 10@L5.1@High
    HDR_Format/String : SMPTE ST 2086, HDR10 compatible
    CodecID : 36
    Šířka : 3 840pixely
    Výška : 2 160pixely
    Poměr stran : 16:9
    Frame rate : 23,976 (24000/1001) FPS
    ColorSpace : YUV
    ChromaSubsampling/String : 4:2:0 (Type 2)
    BitDepth/String : 10 bits
    colour_range : Limited
    colour_primaries : BT.2020
    transfer_characteristics : PQ
    matrix_coefficients : BT.2020 non-constant
    MasteringDisplay_ColorPrimaries : Display P3
    MasteringDisplay_Luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
    MaxCLL : 992 cd/m2
    MaxFALL : 120 cd/m2
    Video #2
    Formát : HEVC
    CodecID : 36
    Šířka : 1 920pixely
    Výška : 1 080pixely
    Poměr stran : 16:9
    ColorSpace : YUV
  28. Member hydra3333's Avatar
    Oct 2009
    Australia
    e.g. Joker (2019)
    Can't explain that, it works with a known good source.
    Try some other known good sources downloadable at that website, just to check.
    Given that known good sources work OK, suspect perhaps your movies may be flagged as encoded 10-bit however during the "capture" process (whatever it was) the colours may have undergone an "unfortunate" conversion resulting in what you see when playing those movies. Can only really tell by playing some more known good sources so as to prove it is related to the source rather than the software.
  29. Member
    Jan 2020
    The Netherlands
    Sorry to hijack this thread, but I am trying to get HDR content to play with MadVR and whenever I try to play HDR content, it will only play in windowed mode (fullscreen turns the screen black) I can get the video to show in full screen if I right click to bring up the right click menu in MPC-BE but closing the menu makes the screen go dark again.
    Screen is 49" Samsung CRG90 it automatically switches to HDR mode when a HDR video file is opened and MadVR renderer is selected. If I set Windows HDR to on first then the picture is gray/washed out.. it looks better if MadVR auto switches the screen displayport to HDR mode so I leave the Windows setting alone.
    I did this:
    1. Ensured 64-bit registration of the madVR .ax (for win10x64)
    2. Changed these madVR options:
    under devices, properties, set "the native display bitdepth is" to "10 bit (or higher)" (I tried 8-bit too which is what my screen switches to)
    [Attachment 51375 - Click to enlarge]
    [Attachment 51376 - Click to enlarge]
    Appreciate any help here!
  30. use D3D11 in rendering settings of madVR
