I've been using 4K Video Downloader to download videos from YouTube, but there's a noticeable drop in quality compared to the original upload, like increased pixelation, slight colour loss and not as sharp, more blurry, general degradation of detail. Is there a better piece of software or website that lets you download in it's original quality (or close to?)
Or would i get better results using screen capture software?
Results 1 to 30 of 56
MPC-HC has youtube-dl integrated as well. But you may not have full control over the preferred format.
YouTube/Google will always recompress videos after they have been uploaded, even if you upload a well supported original resolution. The unaltered upload may not be available to the whole audience (maybe only to the uploader, if it is kept at all). -
It's like you say. Supposedly you can download your own original uploads via google takeout. I have not tested this.
If you're saying the download suffers in comparison to your original upload, that's because YouTube reencodes everything at relatively low bitrates.
If you download at the highest available resolution you're getting the best possible quality that YouTube has to offer. -
Funnily enough, for a video provided with a low bitrate to begin with, due to its highly compressible nature, YouTube can re-encode at a higher bitrate.
I just tested with this one of mine (I apologize in advance for the goofy nature of the topic... it is based on a french meme which emanated from this) :
https://youtu.be/R0IGeGFkuks
The uploaded video, in 1280x720 resolution, encoded with ffmpeg using libx264 and parameters -crf 20 -preset veryslow from a lossless export from the NLE, has a size of 12.6MB (exactly 13278637 bytes), with a video bitrate of 115kbps and an audio bitrate of 185kbps. The video is mostly made of still pictures, which explains the low bitrate requirement.
The video downloaded in the same resolution from YouTube with youtube-dl and the command :
has a size of 21.3MB (22413234 bytes), a video bitrate of 388kbps, an audio bitrate of 128kbps.Code:youtube-dl -f 22 https://youtu.be/R0IGeGFkuks -o "YT - %(title)s [%(id)s -f 22].mp4"
With the format code “136+140” instead of “22” (which requests the download of video-only stream “136” plus audio stream “140” which are then muxed with ffmpeg) the size and global bitrate are slightly higher : 21.5MB / 22598709B, 524kbps instead of 520kbps, although the individual streams' bitrates are the same, I don't know how to explain this. The video stream (extracted with mplayer -dumpvideo -dumpfile) is exactly the same for each file (same size and MD5), while the audio stream (extracted with mplayer -dumpaudio -dumpfile) is slightly larger for the “136+140” file (5520776B instead of 5520033). The “22” file has its index at the begining, the “136+140” one at the end.
Original :
Downloaded (-f 22) :Code:Général Nom complet : H:\conversions et montages (était sur SSD part TEMP)\Google Translate - Coucou tu veux voir ma bite.mp4 Format : MPEG-4 Profil du format : Base Media Identifiant du codec : isom (isom/iso2/avc1/mp41) Taille du fichier : 12,7 Mio Durée : 5 min 45s Débit global moyen : 308 kb/s Application utilisée : Lavf58.19.102 Vidéo ID : 1 Format : AVC Format/Info : Advanced Video Codec Profil du format : High 4:4:4 Predictive@L5 Paramètres du format : CABAC / 16 Ref Frames Paramètres du format, CABAC : Oui Paramètres du format, RefFrames : 16 images Identifiant du codec : avc1 Identifiant du codec/Info : Advanced Video Coding Durée : 5 min 45s Débit : 115 kb/s Largeur : 1 280 pixels Hauteur : 720 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 30,000 Im/s Sous-échantillonnage de la chrominance : 4:4:4 Profondeur des couleurs : 8 bits Type de balayage : Progressif Bits/(Pixel*Image) : 0.004 Taille du flux : 4,74 Mio (37%) Bibliothèque utilisée : x264 core 157 r2935 545de2f Paramètres d'encodage : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x1:0x131 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=4 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Identifiant du codec : mp4a-40-2 Durée : 5 min 45s Type de débit : Constant Débit : 185 kb/s Canaux : 2 canaux Channel layout : L R Echantillonnage : 48,0 kHz Images par seconde : 46,875 Im/s (1024 SPF) Mode de compression : Avec perte Taille du flux : 7,59 Mio (60%) Default : Oui AlternateGroup/String : 1
Downloaded (-f 136+140) :Code:Général Nom complet : H:\YT - Coucou tu veux voir ma bite – Version internationale [R0IGeGFkuks 22].mp4 Format : MPEG-4 Profil du format : Base Media / Version 2 Identifiant du codec : mp42 (isom/mp42) Taille du fichier : 21,4 Mio Durée : 5 min 45s Type de débit global : Variable Débit global moyen : 520 kb/s Date d'encodage : UTC 2019-03-20 06:58:55 Date de marquage : UTC 2019-03-20 06:58:55 gsst : 0 gstd : 345048 Vidéo ID : 1 Format : AVC Format/Info : Advanced Video Codec Profil du format : Main@L3.1 Paramètres du format : CABAC / 3 Ref Frames Paramètres du format, CABAC : Oui Paramètres du format, RefFrames : 3 images Identifiant du codec : avc1 Identifiant du codec/Info : Advanced Video Coding Durée : 5 min 45s Débit : 388 kb/s Largeur : 1 280 pixels Hauteur : 720 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 30,000 Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 Profondeur des couleurs : 8 bits Type de balayage : Progressif Bits/(Pixel*Image) : 0.014 Taille du flux : 16,0 Mio (75%) Titre : ISO Media file produced by Google Inc. Created on: 03/19/2019. Date d'encodage : UTC 2019-03-20 06:58:55 Date de marquage : UTC 2019-03-20 06:58:55 Gamme de couleurs : Limited Coordonnées de chromaticité : BT.709 Caractéristiques du transfert : BT.709 Coefficients de la matrice : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Identifiant du codec : mp4a-40-2 Durée : 5 min 45s Type de débit : Variable Débit : 128 kb/s Canaux : 2 canaux Channel layout : L R Echantillonnage : 44,1 kHz Images par seconde : 43,066 Im/s (1024 SPF) Mode de compression : Avec perte Taille du flux : 5,26 Mio (25%) Titre : ISO Media file produced by Google Inc. Created on: 03/19/2019. Date d'encodage : UTC 2019-03-20 06:58:55 Date de marquage : UTC 2019-03-20 06:58:55
In this case the re-encoding serves absolutely no purpose, but their stupid algorithm has to do it anyway.Code:Général Nom complet : H:\YT - Coucou tu veux voir ma bite – Version internationale [R0IGeGFkuks 136+140].mp4 Format : MPEG-4 Profil du format : Base Media Identifiant du codec : isom (isom/iso2/avc1/mp41) Taille du fichier : 21,6 Mio Durée : 5 min 45s Débit global moyen : 524 kb/s Application utilisée : Lavf58.19.102 Vidéo ID : 1 Format : AVC Format/Info : Advanced Video Codec Profil du format : Main@L3.1 Paramètres du format : CABAC / 3 Ref Frames Paramètres du format, CABAC : Oui Paramètres du format, RefFrames : 3 images Identifiant du codec : avc1 Identifiant du codec/Info : Advanced Video Coding Durée : 5 min 45s Débit : 388 kb/s Largeur : 1 280 pixels Hauteur : 720 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 30,000 Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 Profondeur des couleurs : 8 bits Type de balayage : Progressif Bits/(Pixel*Image) : 0.014 Taille du flux : 16,0 Mio (74%) Titre : ISO Media file produced by Google Inc. Created on: 03/19/2019. Gamme de couleurs : Limited Coordonnées de chromaticité : BT.709 Caractéristiques du transfert : BT.709 Coefficients de la matrice : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Identifiant du codec : mp4a-40-2 Durée : 5 min 45s Type de débit : Constant Débit : 128 kb/s Canaux : 2 canaux Channel layout : L R Echantillonnage : 44,1 kHz Images par seconde : 43,066 Im/s (1024 SPF) Mode de compression : Avec perte Taille du flux : 5,27 Mio (24%) Titre : ISO Media file produced by Google Inc. Created on: 03/19/2019. Default : Oui AlternateGroup/String : 1
Several years ago, if the videos were in the same format as what they used (FLV at the time, I believe), they didn't reencode. However, I believe they decided to reencode everything because of malware that might be hidden within the uploaded videos.
In the OP's case, though, he's not asking about videos that were crap to begin with. -
Just thought of this. One of the reasons Youtube may reencode videos is to prevent people from using it as file storage. Especially if you set the video to private.
Edit; I never heart about Google Takeout and after reading this article, I still don't understand what it does beyond Google Drive. But, what it isn't is an alternative to Youtube downloads for the non-uploader as it's personal storage. https://www.androidguys.com/tips-tools/google-takeout-what-is-it-how-use-it/Last edited by lingyi; 22nd Aug 2019 at 16:03.
Well, crap is an excellent fertilizer...In the OP's case, though, he's not asking about videos that were crap to begin with.
Another inconsistency I just noticed coincidentally :
– This video shows a single still picture in quite poor quality, yet the downloaded 1280x720 file has a relatively high video bitrate of 598kbps.
– This similar video shows several still pictures in better quality, yet the downloaded 1280x720 file has a very low video bitrate of 89kbps. -
I use 4k downloader and there is a slight loss in video quality compared to when I watch it on the youtube channel.
Tried with youtube-dl (cmd command) and it gives exact same result, a slight loss of quality, small, but enough to make you want to watch the video on youtube instead of the downloaded file. It's not lossless.
Any solution?Last edited by ScareDe2; 26th Apr 2020 at 20:41.
youtube-dl can download the same streams you see in the browser. Either:
1.) you are not downloading the same streams (in youtube right-click -> "stats for nerds" shows you which streams you are watching) or
2.) you are imagining things or
3.) your player is somehow worse/different than your browser's video playback
[Attachment 52925 - Click to enlarge]
[Attachment 52926 - Click to enlarge] -
When you upload a video to YouTube, it will always be re-encoded there, for several reasons (e.g. to avoid embedded malware, and to optimize the bitrate distribution for streaming purposes). When you download a publicly presented video format and compare it with the video you uploaded, there will be quality loss.
Your original upload may be stored additionally, but I don't know for sure under which circumstances this happens, possibly not for all content producers, and it will surely not be available for presentation. -
It's easier to detect the difference watching a video sequence showing water sparkling in sun light. But I can detect it with pretty much any image really. I tried to copy paste the video in my browser and watch it there, but there is still a difference compared to when I watch it on the youtube channel. Maybe the youtube player is more performant? I tried VLC, Windows player, a couple of others along with the browser player - always a slight decrease in quality.
I am gonna pay more attention to the number you show and retry a download.
And same problem again. Any solution?Last edited by ScareDe2; 28th Apr 2020 at 15:43.
Maybe the YouTube presentation in the website is scaled, so there you don't see the video 1:1 as encoded?
I can rescale everything to match perfectly, and when comparing the downloaded file with the one seen on the youtube channel, the image is not the same. You don't see that? I can agree that it is subtle, but... the downloaded file is definitely worst.
Or maybe the youtube player has an hidden filter embellishing the image, I don't know. -
UniConverter ! copy&paste the url of the YT video, or any url of a page from a videoclip, any you can choose the resolution, easy to work with or you only download the sound into mp3 file,
it's a paid app, but has many more feautures, you like, convert, edit, color effects/correction, etc.. -
I had one free download with UniConverter and it gave the same result than with youtube-dl. I start to assume there is no possible way to download a better version of the youtube video. So it has to be either youtube sending a slightly compressed file during the download or the youtube player doing some tricks like adding a filter so the image looks nicer. I don't see any other possibilities. Any clue?
Here is an example, capture from the browser player playing the downloaded file (any downloaded files gave same result, either from youtube-dl, UniConverter, 4k downloader, ect...)
And here is the capture from the youtube video
Don't know.... UniConverter i use on my MacBook Pro, i can't see any quality loss, youtube-dl isn't available on Mac OS, UniConveter is much more, you can select which resolution stream you want to download so maybe it's overkill to just use it for saving Youtube videos, i also use it to convert my VHS captures, BBC sound streams, (not the iPlayer ones) i find the GUI very comfortable, & user vriendly
you can check what is available on youtube using this command (already shown above): youtube-dl -F link-to-your-video
It basically looks very similar but if you look closely you can see the color are a bit more lively on youtube while the "lossless" download gives a deader picture, and I would say some three-dimensionality loss. The video above was filmed in 1989 in an amusement park and it shows quite a lot of interesting coasters and point of views making it an amazing document about how the site was 30 years ago. Only problem is, I find the youtube version way better to watch.
UniConverter has color correcting options for that, but it is like said before, a matter of taste, and seing both versions next to eachother....
I have everything installed following a youtube tutorial (MPC-HC, madvr, Lavfilter and xysubfilter), but pressing ctrl+shift+alt+m doesn't work. I don't know how to change color conversion either.
BTW I highly recommend youtube-dl. Yes it is command line, but once you get used to it, it is so much simpler than all the GUI tools.
What I can't figure out is why on YouTube you can watch this video in 1080p, but... when you query the resolutions (1st command) it claims the highest resolution is only 720p. Also, when you download it asking for the highest quality, it only pulls down 720p intead of 1080p...
C:\youtube-dl.exe -F https://www.youtube.com/watch?v=oegRlg9V4q8
C:\youtube-dl.exe -f bestvideo+bestaudio https://www.youtube.com/watch?v=oegRlg9V4q8 -
Try with the command youtube-dl -f 248+251 https://www.youtube.com/watch?v=oegRlg9V4q8
As shown above in an earlier post, right click the youtube video, click stats, then you see the codecs line ending with (248)/opus (251). That means -f 248+251. And you have the 1080p. Works? -
Cannot download videos with YouTube-dl even AFTER Update.
By decoder in forum Video Streaming DownloadingReplies: 8Last Post: 5th Jul 2018, 14:32 -
How to download videos from Tumblr ( using youtube-dl )?
By devilcoelhodog in forum Video Streaming DownloadingReplies: 3Last Post: 11th Aug 2017, 10:20 -
How to Download Youtube Paid Videos
By Drunken King in forum Video Streaming DownloadingReplies: 1Last Post: 12th Nov 2016, 00:02 -
Sudden Loss in Video Quality (YouTube)
By midiout in forum Video Streaming DownloadingReplies: 5Last Post: 2nd Jul 2015, 13:43 -
How to download youtube DRM videos
By pokkiri in forum Video Streaming DownloadingReplies: 1Last Post: 10th Jan 2015, 02:26
