Results 1 to 24 of 24
  1. Hello
    I downloaded a documentary from medici.tv with youtube-dl GUI and it worked well.
    Now I'm trying to rip subtitles from the same docu (they are splitted into many .webvtt segments) using Firefox and activate developer mode to inspect element. Then head to Network tab to find and search for: 'subtitles' or 'm3u8'.
    What I get is a file of about 70 KB with .mp4 container.
    I opened the file with notepad and this is the (partial) content:
    WEBVTT
    00:00:00.000 --> 00:00:04.280
    Le piano est un instrument
    plutôt neutre.
    X-TIMESTAMP-MAP=MPEGTS:2415600,LOCAL:00:00:00.000
    00:00:00.320 --> 00:00:04.439
    Mais il a des possibilités illimitées
    de se transformer.
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:2815110,LOCAL:00:00:00.000
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:2941110,LOCAL:00:00:00.000
    00:00:00.000 --> 00:00:06.080
    C'est ainsi qu'il peut devenir
    un instrument chantant...
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:3488310,LOCAL:00:00:00.000
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:4262400,LOCAL:00:00:00.000
    00:00:00.000 --> 00:00:02.520
    De voir que cet instrument
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:4489200,LOCAL:00:00:00.000
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:4546800,LOCAL:00:00:00.000
    00:00:00.000 --> 00:00:03.040
    réagit véritablement,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:4820400,LOCAL:00:00:00.000
    00:00:00.160 --> 00:00:04.760
    et se plie
    à ce que vous voulez faire,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:5248800,LOCAL:00:00:00.000
    00:00:01.599 --> 00:00:03.560
    à ce que vous cherchez,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:5569200,LOCAL:00:00:00.000
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:5583510,LOCAL:00:00:00.000
    00:00:00.000 --> 00:00:03.000
    est quelque chose d'extraordinaire,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:5853510,LOCAL:00:00:00.000
    00:00:00.441 --> 00:00:03.880
    la raison pour laquelle je suis,
    encore aujourd'hui,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:6202710,LOCAL:00:00:00.000
    00:00:00.161 --> 00:00:02.041
    heureux d'être pianiste.
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:6386400,LOCAL:00:00:00.000
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:15670800,LOCAL:00:00:00.000
    ---truncated
    then I renamed the file as .vtt and converted it as .srt with Subtitle Edit.
    What i get is a file like this:
    1
    00:00:00,000 --> 00:00:04,280
    plutôt neutre.
    2
    00:00:00,000 --> 00:00:03,760
    Mes premières rencontres
    avec Abbado remontent
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:204764400,LOCAL:00:00:00.000
    3
    00:00:00,000 --> 00:00:02,720
    Il était clair
    que ce genre d'activité
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:194860800,LOCAL:00:00:00.000
    4
    00:00:00,000 --> 00:00:02,960
    dans la vie musicale italienne.
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:195951510,LOCAL:00:00:00.000
    5
    00:00:00,000 --> 00:00:03,440
    sinon de façon très limitée.
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:196556400,LOCAL:00:00:00.000
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:196750800,LOCAL:00:00:00.000
    6
    00:00:00,000 --> 00:00:01,320
    Oui,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:197899200,LOCAL:00:00:00.000
    7
    00:00:00,000 --> 00:00:02,520
    Vous avez joué Bartók
    sans répétition ?
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:221727600,LOCAL:00:00:00.000
    8
    00:00:00,000 --> 00:00:01,120
    mais en fait,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:198000000,LOCAL:00:00:00.000
    9
    00:00:00,000 --> 00:00:01,256
    des autres.
    10
    00:00:00,000 --> 00:00:01,480
    Abbado est un peu plus âgé
    que moi,
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:205318800,LOCAL:00:00:00.000
    ---truncated
    The result does not seem to be a correct .srt file. In fact, combined with video, timestamps are busted, completely useless and out of sync.
    Am I wrong in converting from .vtt to .srt or should I look for a different key with the developer tool?
  2. LZAA это то же самое, что и здесь
  3. Originally Posted by LZAA View Post
    Url?
    not resolved
  4. I guess this should be simple to fix using regular expressions.
    Find:
    ^(WEBVTT|X-TIMESTAMP-MAP.*)(\r\n|\r|\n)
    and replace by nothing.
    Editors like Notepad++ and SublimeText offer such Search and Replace (All) feature with regex.
  5. But timing problem remains. It does not seem regular as expression...
  6. Sorry, I didn't see the timing problem. Indeed, that seems to be the complicated part.
    I'm wondering if it is even possible to reconstruct the correct timings from just the info you posted.
    Does the following fit the video?
    plutôt neutre.
    2
    00:00:26.840 --> 00:00:30.279
    de se transformer.
    3
    00:00:32.679 --> 00:00:38.759
    4
    00:00:47.36 --> 00:00:49.880
    5
    00:00:50.520 --> 00:00:53.560
    6
    00:00:53.560 --> 00:00:58.320
    et se plie
    7
    00:00:58.032 --> 00:00:61.880
    8
    00:01:02.039 --> 00:01:05.039
    9
    00:01:05.039 --> 00:01:08.919
    encore aujourd'hui,
    10
    00:01:08.919 --> 00:01:10.960
  7. Originally Posted by sneaker View Post
    plutôt neutre.
    2
    de se transformer.
    3
    4
    5
    6
    et se plie
    7
    8
    9
    encore aujourd'hui,
    10
    Nope... it should be like this:
    WEBVTT
    1
    00:00:22.020 --> 00:00:27.004
    The piano is finally
    a rather neutral instrument.
    2
    00:00:27.008 --> 00:00:31.018
    But it has a limitless ability
    to transform itself.
    3
    00:00:31.022 --> 00:00:35.005
    Thus, it can become
    4
    00:00:37.003 --> 00:00:39.003
    a singing instrument...
    5
    00:00:47.017 --> 00:00:50.001
    To see how this instrument
    6
    00:00:50.005 --> 00:00:53.018
    actually reacts,
    7
    00:00:53.022 --> 00:00:58.013
    and yields
    to whatever you want to do,
    8
    00:00:59.010 --> 00:01:02.001
    to what you are after,
    9
    00:01:02.005 --> 00:01:05.012
    is something quite extraordinary.
    10
    00:01:05.016 --> 00:01:09.005
    This is why I still am,
    11
    00:01:09.009 --> 00:01:11.003
    so happy to be a pianist.
    I can provide access if needed.
  8. I probably won't be able to help. I cannot even manually get from the quotes in post #1 to the file from post #8, let alone in an automated way. I think it's not possible but you need more data.
  9. Originally Posted by sneaker View Post
    Thanks for your reply. I finally succeeded with Allavsoft
    I will also try with URL Snooper.
  11. I have the exact same problem as the OP.
    I used FFMPEG to download subs from the same web site with the following command:
    ffmpeg -i "https://sdn-global-streaming-cache-3qsdn.akamaized.net/stream/9378/files/18/12/1068412/9378-HWQKVTXrYyxwncZq.ism/9378-HWQKVTXrYyxwncZq-textstream_eng=1000.m3u8?mime=mp4&source=html5" subs.srt
    The result is identical to youtube-dl and so it should be because youtube-dl uses FFMPEG to download and convert subs.
    I downloaded one of the VTT segments from the above playlist:
    WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:43875090,LOCAL:00:00:00.000
    5
    00:00:00.000 --> 00:00:02.791
    What do you think
    of her over there?
    It appears that in a segmented VTT the timestamp is indicated by the MPEGTS value, which is offset by 1 second (90000). The correct start time (in seconds) could therefore be calculated by dividing the MPEG-TS by 90000, less one. FFMPEG/youtube-dl merely copies and pastes the local time, which in a segmented WebVTT is always zero.
  12. Anonymous
    Guest
    WEBVTT
    5
    What do you think
    of her over there?
    Hello paralucent,
    Make sure it's right for you, because I'm not sure.
    check both.
    https://mega.nz/folder/iNZinI5a#tsu-HOff_GHWA4CwqZsTLw
  13. Thank you so much marcelo_bor! The first one, subtitle A, was perfect!
    How did you do it?
  14. Anonymous
    Guest
    How did you do it?
    so i used the m3u8x program.
    here is the link> https://www.videohelp.com/software/m3u8x
    caption b is 10 seconds late then.
    done.
  15. Thanks for the info. I started to install m3u8x a few days ago but a Windows Security Warning box appeared saying the certificate is from "DO_NOT_TRUST_FiddlerRoot". Did you get the same message?
  16. Anonymous
    Guest
    It definitely didn't come to me.
    you don't need to install anything, just extract the program to a folder and use it remembering that it is portable.
    if you feel safe, go ahead on the program or search for information on 'DO_NOT_TRUST_FiddlerRoot' on google.
  17. Thanks got it working.
    If I paste the m3u8 subtitles URL in the 'Quality URL box' and then click 'Download' I don't get any messages about certificates. In order to obtain correctly synched subs I found I needed to select 'time according to EXTINF'. Thanks again for your help, marcelo_bor.
  18. As for as my test, Allavsoft can download both videos and subtitles from medici tv. Simply copy and paste the medici tv video link to Allavsoft and click Download button, it will download both subtitles and videos into the Download folder.
    Sep 2005
    Darkest Peru
    Same problem with another site. When I use m3u8x I get a folder of 141 en.m3u8_0000000000.vtt files containing text like: WEBVTT
    X-TIMESTAMP-MAP=MPEGTS:126000,LOCAL:00:00:00.000
    I'm sure I"m doing something wrong. m3u8x is kind of hard to understand though.
    I run m3u8x. Paste the subtitle playlist into the box that says "Quality URL", check 'This Subtitle' and "One...One", and 'Download'.
    A box opens, I click 'Time according to "EXTINF" and 'Start download'.
    Am I missing something? I can get the subtitles complete and merged with ffmpeg, but it's full of garbage and has timing errors like mentioned above.
  20. that m3u8x download box when you finish downloading all parts, click 'Combine' button on the top
    Then it should build a merged srt for you
  21. there's disney+ addon on greasy fork that act like this so maybe modify ?
  22. Member
    Sep 2005
    Darkest Peru
    I don't see a combine button. Also, I think there is an issue with there being commercial breaks and that the subtitle count restarts after each one. As a result m3u8x assumes it already download all segment by the first break.
    I don't think it's the right tool.
    Do I run into site rule issues if I mention what streaming site I'm looking at?
    Edit: It looks like there is an ffmpeg patch for this that has never been added. Is there a way to institute that myself? https://gist.github.com/SebiderSushi/bdf8d46d5501f7085d0b27d8a19eb12c
