Hi,
i'm on ubuntu and i have created several costum actions in thunar to open mime types with specific applications. i also want to do this with matroska files and the mkvpropedit gui. the command to start it is 'mkvpropedit' but thats only the command line version, gut the gui. mkvpropedit --gui-mode filename doesn't work, there is the error "nothing to do". The only way i know is to open mkvtoolnix-gui and then go to the header editor. i want to open files directly in the editor.
Valit
https://mkvtoolnix.download/doc/mkvtoolnix-gui.htmlCode:
mkvtoolnix-gui --edit-headers "file.mkv"
Need help Using MKVpropedit Scripts, or JMKVpropedit
By AManOfCharacter in forum EditingReplies: 5Last Post: 12th Apr 2020, 12:14 -
mkvpropedit batch track select by idiom
By chemba in forum SubtitleReplies: 0Last Post: 12th May 2018, 10:39 -
mkvpropedit to set language
By WakaFlakaFlakes in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2017, 15:38 -
MKVToolNix GUI - Splitting a file with multiple file parts added to it
By MisterNewb in forum EditingReplies: 5Last Post: 13th Sep 2015, 11:47 -
Scrtipt to use mkvpropedit to change title
By mkr10001 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Sep 2014, 06:00
