With every dvd ive placed in my dvd drive when i start smart ripper it says files are still locked, although i can ignore this but when i try to do the rip absolutley nothing happens, whats wrong with it??????
As it states in most of the guides and many posts, you typically have to start playing the DVD with some player app BEFORE you begin your rip process.
I had one dvd do that. What I found was that it just wouldn't open on that particularly dvd rom. Fortunately, I had another computer with a dvd rom and was then able to rip it on that rom. Might try another rom if you can. BTW, when this happened to me, I tried about 5 different ripping programs all with the same result....it was the rom not the software.
Locked MKV files, Multiple Instances of Explorer, PC Lag
By pushkin69 in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 23:22 -
WTF is with Ebay?!?!
By Noahtuck in forum Off topicReplies: 7Last Post: 29th Dec 2009, 19:33 -
From the WTF? Files
By Soopafresh in forum Off topicReplies: 7Last Post: 19th Apr 2009, 16:46 -
wtf is it?
By zoobie in forum Off topicReplies: 10Last Post: 25th Dec 2008, 17:03 -
Man + balletcostume = WTF!?
By cityman07 in forum Off topicReplies: 0Last Post: 3rd Sep 2007, 15:23
