Hello everyone!
I am really frustrated
I retested my LGP2 to record the Video of my Sony Alpha 5100.
And wow, at first it worked really well. I had quite a great video quality while recording.
Then RECentral crashed (happens so often :/ ).
I couldnt get it to work again.
So I thought, maybe I should update all LGP2 firmware. (GC510_3.0.0.16)
After that, everything went wrong....
I had so many bugs, crashed and problems since then.
But what drives me really crazy is the drop in the video quality.
First: in the PC-free mode, before the update, the LGP2 recorded at around 20 mbit/s.
After the update it now only records in around 7 mbit/s. Albeit I set the quality in RECentral for PC-free to high.
But the real bummer is:
In PC-Mode I get totally crap video quality now. Its so blurry and although RECentral records at e.g 60mbit/s, the quality looks like 2mbit/s.
I changed and tested quite a few different settings, but still:
After the firmware update everything is broken. Now I can't use the LGP2 for what I wanted in the first place (the quality is to low).
Also I wasn't able to downgrade the firmware update (the LGP2 just doesn't update, when I put the old update-file in the update-folder on the sd-card).
So my questions now are:
1) Is there a way to downgrad the firmwar of the LPG2?
2) Does andyboy else has/had experiences like mine?
3) Do I miss something and the solution is very simple?
Thanks a lot !!!![]()
Results 1 to 1 of 1
System requirements for AVerMedia Live Gamer Portable
By kosmaspar in forum Capturing and VCRReplies: 0Last Post: 26th May 2017, 19:32 -
Avermedia Live Gamer Portable Resolution Problem
By Suikadon in forum Capturing and VCRReplies: 0Last Post: 4th Dec 2015, 08:25 -
AVerMedia Live Gamer Portable and Converter Issue
By PureChaosX in forum Capturing and VCRReplies: 10Last Post: 20th Aug 2015, 06:38 -
Having problems with my Avermedia Live Gamer Portable.
By Masteroliw in forum Capturing and VCRReplies: 9Last Post: 18th Feb 2015, 05:00 -
Avermedia Live Gamer Portable Captured Video Specs and Questions
By Yarotska in forum Capturing and VCRReplies: 9Last Post: 19th Oct 2014, 03:56
