What are the current costs to send VHS tapes out by mail and have them captured and digitized? U.S.-based shops with proven track record would be preferred.
I'm looking at 10-15 VHS tapes, a mix of NTSC, PAL, and SECAM, recorded at various speeds (no idea which tapes were recorded at which TV standards and which speeds).
Targeted format is:
- lossless video (FFV1 is pretty good from what I've read?)
- Perhaps FLAC audio (to save space over PCM)
- MKV container
- I assume NTSC and PAL tapes would be captured at their respective standard resolutions, is that correct?
I want the absolute best VHS players and capture hardware to be used. How much would this job cost, per hour of video?
Contact lordsmurf. He provides transfer services. Not sure about PAL and SECAM though.
There are several members who do this work.
lordsmurf has been mentioned. johnmeyer is another
I would have thought that both can handle multi standards since you only need a multi-standard vcr for that
Some months ago a guy came to the forum boasting of his 'studio' to do this work. The topic is worth a read just for his nonsense
https://forum.videohelp.com/threads/388888-An-actual-VHS-to-Digital-Studio
And how much he was charging per tape. That itself will makes your eyes water -
As has been discussed here, multi-standard VCRs may not output a true PAL or SECAM signal. Also, in addition to a VCR, a compatible TBC, capture device and processor if used are necessary.
Maybe I passed those topics. It has always been my understanding that a proper multi-standard vcr can handle these broadcast standards. Many moons ago I sent off tapes of both Brasil and Russian recordings to a guy who then offered the service as a standards conversion using two multi-standard vcrs. In return I received PAL tapes.
Of course you would also require a multi-standard tv to view the output. -
For reference, it was recently discussed here: https://forum.videohelp.com/threads/392974-What-do-you-consider-the-best-PAL-NTSC-SECAM-VHS-player and here https://forum.videohelp.com/threads/392960-Is-the-quality-output-of-these-vcrs-lowered...-multi-support
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 05:10 -
difference between using a s-vhs scart socket contra a s-vhs s-video jack
By Desve in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2019, 10:59 -
Hi8 Digitization Help
By ssbbnw in forum Capturing and VCRReplies: 9Last Post: 25th Jan 2017, 15:28 -
How to create an mpg, mp3 or mp4 file from VHS? (Using Honestech VHS to DVD
By CambridgeChris in forum Capturing and VCRReplies: 2Last Post: 29th Dec 2016, 09:29 -
Honestech VHS to DVD 2.0 - Software not recording although VHS is playing
By emma1994 in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2016, 17:11
