So basically my setups is as follows;
AMD Ryzen 7 1700x 8 core 16 threads
16GB Ram
Radeon RX550 Series
Windows 10 64 bit
Avisynth+ latest version as of yesterday and AVSPmod
My issue is I'm working on my script in AVSPMod and it previews fine in AVSMod. However, when I run the below CMD Prompt command, it loads for about 10 seconds then disappears. If I drag the .avs file into Virtualdub and try to save as an .avi there, it also crashes. Is there something wrong with my script or is there a better way for me to save to Huffyuv that what I am current doing?
Update: I have tried with my source as an .avi file and it seems to work now. So what would I change in order to edit a ripped .mpg from DVD?
Command prompt line (through.bat file)
Avisynth ScriptCode:ffmpeg -i "dbz.avs" -c:v prores -profile:v 3 -pix_fmt yuv422p10le -c:a pcm_s16le "dbzfinal.mov"
Code:SetFilterMTMode("QTGMC", 2) FFmpegSource2("dbz.raw.mpg", atrack=-1) ConverttoYV12() AssumeTFF() QTGMC(Preset="Slower", Edithreads=7) Hysteria(strength=1.0) LSFmod() dfttest(sigma=20) Spline64Resize(720,540) Trim(150000,160000) Crop(12, 2, -8, -2) Prefetch(Threads=15)
Is the video actually raw (elementary stream)dbz.raw.mpg
If yes are you sure the extension is mpg and not m2v -
Yes. But why bother remuxing from VOB to MPG if you don't need to? It's just an extra step where something can go wrong.
On rare occasions remuxing is necessary -- like when the VOB has multiplexed video streams. You need to use a tool like VOB2MPG that will pick out only one of the streams. The IFO files are needed for this because they specify how to pick out a single stream.
Need a particular 3D avisynth script
By mazinz in forum Video ConversionReplies: 8Last Post: 25th Feb 2018, 05:55 -
Need help with AVISynth script
By duffbeer in forum DVD RippingReplies: 13Last Post: 8th Sep 2016, 17:05 -
Best possible AviSynth Script
By Suwadith in forum Video ConversionReplies: 31Last Post: 10th Sep 2015, 07:43 -
Avisynth - What's Wrong with this Script. (FPS Convert/Motion Estimation)
By RAB78 in forum Video ConversionReplies: 41Last Post: 25th May 2015, 14:06 -
Avisynth script help?
By PeterNL in forum Newbie / General discussionsReplies: 6Last Post: 10th Dec 2014, 12:35
