I own the latest version of TMPGENC-Plus, and want to use it to convert a VERY good quality divx to SVCD. I understand the basics of converting to VCD, and I attempted to convert. However, I ended up with a file that was like 3 GB in size, and that was less than a third of the movie.
So my question is - what is the lowest bitrate you can use and still get very good quality? Should I invest in a DVD burner so I can copy files like this and still keep them looking good?
Thanks.
Tim
What template did you use ?
Personally, myself, I would not invest in a dvd burner RIGHT NOW.
The reason being is that to get the same dvd quality, you need a dvd-r above 4.6 gigs. And these are not available YET.
I'm gonna waiting till the duel layer DVD-R burners/disk come out before I invest in a dvd burner. these will have double the capacity then the ones out now.
Just hold tight till then..bro -
try the SVCD ntscFilm template.
you can set the audio bitrate lower--- 192 or even 128 works ok
use a maximum bitrate of 1900-2100 to get 45-55 min on a CD.
I tend to use vbd_cq quality 77 bitrate 1950-- but I usually work with
DVD rips.
ymmv
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56
