I am almost done rebuilding my desktop but i decided to go with a different liquid cooler. So i ordered a Cooler Master Hyper 212 Evo. I am wondering if i need to remove my desktop the fan in the back of the pc for the hyper 212 air to blow out of the back? That's the way ill be facing hyper 212 fan.
Don't remove the rear fan. Since you have PWM available on the MB, I would add a PWM exhaust fan, whatever size fits, but a 120mm or larger would be advised.
Thanks ill keep the rear fan in. I forgot to mention there is a fan in the front of the pc just in front of the hard drives.
Be sure that both fan flow direction is same - avoid situation where flow direction is opposite and nullified in the middle of enclosure.
I cannot get the hyper cooler to get in place of the screws. Is it ok to use my own motheelrboard brace on the back to screw it down inside my case?
CPU Fan Difference??
By jollyjohn in forum ComputerReplies: 3Last Post: 9th Aug 2019, 05:12 -
Need a good fan for ATI 9600 Pro
By Master Tape in forum ComputerReplies: 1Last Post: 27th May 2019, 15:16 -
Wanting to try my hand at a fan edit
By solkap in forum Newbie / General discussionsReplies: 15Last Post: 2nd Feb 2019, 21:35 -
Remove back to main-menu from DVD?
By schumi2k4 in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2015, 17:48 -
PotPlayer - Fan speed when paused?
By vdoep86 in forum Software PlayingReplies: 3Last Post: 11th Apr 2015, 05:52
