I am not a professional, but I need to transfer a series of DigiBeta tapes. I’ll use a Sony J30/SDI to do it. My PC (Intel core i7, graphics card Gigabyte Z390UD, 16 GB RAM) is equipped with the Blackmagic Decklink SDI 4K. The card is installed correctly (cf. device manager) with the latest drivers, and is recognized by Blackmagic Media Express and by Adobe Premiere Pro CC.
To test the combination before hiring the Sony J30/SDI, I connected my Sony DSR-20P using a SDI cable. Yet, I cannot capture: Blackmagic Media Express and Adobe Premiere do not find the Sony DSR-20P device. However, when I connect the Sony DSR-20P to my PC using a firewire cable, Adobe Premiere manages to capture without any problem (not Blackmagic Media Express because it needs the Blackmagic Decklink SDI connection).
Why do the programs not recognize the Sony DSR-20P when I use a SDI cable? Can it be that something is wrong with my SDI cable or with the SDI output of the Sony DSR-20P? Or is there any feature I omitted?
Thank you very much for your help.
The DSR-20P does not have an SDI output. It has composite, S-Video and DV.
SDI and composite use identical BNC connectors, perhaps that is the cause of the confusion?
https://www.broadcaststore.com/pdf/model/17001/dsr20.pdf
https://pro.sony/s3/cms-static-content/operation-manual/3861406151.pdf
Audio sync issues capturing with DSR-11
By bloodmark in forum Capturing and VCRReplies: 0Last Post: 25th Jul 2019, 09:24 -
Sony j30 SDI no Signal
By ideiasnoescuro in forum Capturing and VCRReplies: 4Last Post: 4th Jan 2019, 06:01 -
Will a Sony DVCAM DSR-20MDP play 60 minutes on a tape recorded 60 minutes?
By snufsis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jun 2017, 21:00 -
Sony TRV-340E replacement RCA cable 3.5mm
By pavion in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 21st Apr 2017, 13:58 -
Canon XF200 SDI out
By Alex1987 in forum Video Streaming DownloadingReplies: 1Last Post: 25th Apr 2016, 15:24
