Happened to me too a few times. I often run a test encode first to see everything is alright. When I run the final encode I save that with the same name and when I overwrite it get's the runtime from the testfile.
Did you use the standard VCD template or did you change some of the settings. For example I used Sefy's SeVCD template to make a 95min movie fit on one 80min CDR. My DVD player (Apex AD600A) says the movie is 77min long, but when you play the VCD it runs for the full 95min.
Yes, I'm using the standard VCD template that came with TMPGEnc. The settings are the same.
Bayag: A little more info on the test file please. How do make the test file and then have it use the runtime for the final file?
VOB files reporting wrong playing time
By awgie in forum Newbie / General discussionsReplies: 23Last Post: 18th Mar 2021, 07:32 -
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42 -
vlc playing back wrong colors
By octeuron in forum Newbie / General discussionsReplies: 19Last Post: 30th Apr 2010, 03:43 -
iTunes 8 displaying a few songs with the wrong run time
By Nintendo Fan in forum ComputerReplies: 26Last Post: 8th Jul 2009, 19:34 -
Playing AVCHD on plasma using WMP=wrong AR
By EliG in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Oct 2007, 12:54
