  1. I've got a group of rar files that I'm missing some files from. Does anyone know of any way to unrar the incomplete files. There are no pars or fills for these files. I read somewhere that you can copy the partial mpg out of the unrared file folder when the program pauses to tell you that it needs the next missing file. This actually works but the mpg is always the same exact mpg no matter what file I try to unrar. Any ideas?
  2. not a complete answer ...but if you right click and un-rar here ...then watch untill it askes for the file you haven't got ...re-do this time pausing just before it asks you for the file ...then open the folder and copy what it has extracted. Paste in to another folder and watch the film (might have to sometimes rename the extenion) this will let you see up to the missing part.
    hope it helps some
    Birty1
    I hope skirk has solved this....10 years ago....
  4. Member Seeker47's Avatar
    Jul 2005
    Yeah, but it is still a good question that likely keeps coming up for many people. One answer is: Yes, I do this with some regularity, using 7-Zip to do the Un-Rar. It will go ahead and extract whatever is extractable from the archive. That may be -- for example -- part of a video, which can then be checked with VLC. Sometimes pieces of the original RAR archive are no longer available, in which case you're basically hosed. But at least you may be able to get some idea of what was there.
    I'm not sure if other de-archivers might also be able to do this, but I think it's a possibility.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  5. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    This is one of those things I like about your site Baldrick. Here is a good example for all of showing a real good gentle sense of humor when dealing with the innocent. Although I fully appreciate the need to not pollute current topics too many boards are quick to jump in and fry a new guy for resurrecting old threads like that.
    There's not much to do but then I can't do much anyway.
