Update.
I got a FireWire ExpressCard, most of the problems are gone, I can send DV video from Vegas to DV device and record analog VHS, but D-VHS deck (PAL) is not shown in PC as DV device, obviously, so I can't yet send DV to that, but I can get a device that will accept DV signal and output DV signal.
Now, back to PCM audio on D-VHS, I got an NTSC machine with FullHD capability, it works with DVHStool/CapDVHS. The question is if it's possible to get LPCM audio when digitising analog tapes and if it's possible to create TS file with LPCM audio to record D-VHS in HD.
Results 61 to 65 of 65
D-VHS was never a DV device, It is a MPEG-2 SD/HD interlaced format, not even HDV. JVC used firewire because at the time, it was the only digital port that can send HD to a display device or another D-VHS recorder, When HDMI became available JVC used it in their last two sister models.
As far as computer connectivity goes, I believe only US and Japanese NTSC models have the capability to stream to computer.
When digitizing analog tapes, you get PCM audio according to D1 standard, not sure if it's linear PCM or not but it's a 16bit/24bit(pro devices), 48KHz audio, D-VHS doesn't use neither, it uses Dolby digital or DTS, Can stream PCM during playback of the tape after decoding it.
Recording D-VHS is a rabbit hole, we've discussed it here before, to get the full 25Mbps with Dolby digital or DTS (D-Theatre standard) you would need a special script that I talked about in one of my old threads, A Windows XP machine, and DVHSTool app. Note that we couldn't get DTS to work properly so I gave up on it.
Besides firewire, you can only record HD via component but you will be limited to 19Mbps, ATSC over the air standard. -
I know, but PAL D-VHS has DV input, as in it only works for DV input from DV source, I can't play MPEG-TS there. But when connecting a DV VCR and outputting through FireWire the D-VHS sees this signal.
Either CapDVHS, or DVHStool gives me maximum 256 kbps audio when capturing analog, unless there are some settings I need to alter, I wonder if ffmpeg could capture the video with LPCM audio.
Actually, I was able to record D-VHS both SD and HD on Windows 10. Vegas can even render D-VHS compliant file, though with few modifications of the preset. DTS is not needed to me, but I wonder what are the audio options in terms of LPCM, AC3 and AC3 surround.
I found some other thread where the OP was testing the limits of bitrate to see where the threshold is where the video starts exhibiting problems. -
That has to be me, that's the thread I was talking about, and the guy who was working with me cooking the files is the guy who worked on the firewire board of D-VHS for JVC back then.
As of your query, I have no idea what you are trying to achieve, so I can't help any further. -
That checks out. That's exactly what I remember reading there, many thanks. I downloaded the samples from there and they do have LPCM audio tracks according to MediaInfo, though the audio on that track is distorted, unless those files were from yet another thread.
For PAL D-VHS, I know what I need, which is basically a FireWire pass-through device.
Fot NTSC I would like to know:
1. If there is a way to get LPCM audio when rippingthe tapes via FireWire. If not, then I guess 256kbps is fine.
2. If there is w way to record the tape using LPCM audio. If not, I will just use the highest audio bitrate possible in Vegas render, since I will be releasing a film on limited edition D-VHS tapes.
TMPGenc Video Mastering Works 6 Deinterlacing settings
By magnu in forum RestorationReplies: 25Last Post: 8th Aug 2017, 11:43 -
TMPGEnc Video Mastering Works 5
By kalemvar1 in forum Video ConversionReplies: 5Last Post: 5th Sep 2015, 22:37 -
TMPGEnc Video Mastering Works 6 - Avisync support
By bschneider in forum ComputerReplies: 9Last Post: 17th Jun 2015, 13:11 -
TMPGEnc Video Mastering Works v5 - Editing .ts impossible
By vhwul62 in forum Video ConversionReplies: 17Last Post: 21st Sep 2014, 04:46 -
Video Mastering Works is so Slow
By danswano in forum Authoring (Blu-ray)Replies: 7Last Post: 26th Aug 2014, 20:41
