Greetings
Which is the best way to cut a middle section from a video (without converting it)?
I'm using TMPGenc Authoring Works 6 (on Windows 10 Pro) but it saves output as a DVD thus losing quality.
thank you
this is well known but VirtualDub doesn't read mkv
thanks for your quick answer -
VirtualDub2 can both import and export MKV files but it isn't a smart cutter. (A smart cutter can cut on any frame but only re-encodes incomplete GOPs.)
TMPGEnc MPEG Smart Renderer 5 is TMPGEnc's smart cutter.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Trying to cut MKV video, I get corrupt video
By Wilykit in forum EditingReplies: 2Last Post: 29th Nov 2017, 02:12 -
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
Extracted Blu-Ray file that contains both Director’s Cut and Theater Cut??
By alshargi in forum Authoring (Blu-ray)Replies: 1Last Post: 16th Oct 2016, 08:35 -
I want cut video like this
By mmkk in forum Video ConversionReplies: 11Last Post: 21st Mar 2015, 03:21 -
How do I cut part of the video
By defacto in forum Newbie / General discussionsReplies: 8Last Post: 28th Aug 2014, 17:44
