G'day all,
Is there a difference, other than the number, between: Cpu fan E97378-001 ce and
E97379-003 CPU Cooling Fan. My E97378-001 ce, started to snore now and then. Lubrication did nothing to stop it. Both of them look the same, but...
Would the locking pin distances be the same to fit the MB?
Pictures attached
I"ll be very grateful with an answer.
Regards
John
Thick oil (car engine) may help, you may consider to use some oil additive based on MoS (molybdenum disulphide) - should help with bad noise from bearing.
Above may look OT but it is quite obvious that Intel don't produce fan's a.k.a ventilators and as such they may use different brands - higher amperage doesn't mean automatically higher flow, commonly lower quality brands consume more power to deliver similar results - check reputable fan vendor such as Pabst and compare their competition - key to performance (on many areas) is not in motor but in blades - good fan usually is less noisy and deliver same performance using less power.
Wanting to try my hand at a fan edit
By solkap in forum Newbie / General discussionsReplies: 15Last Post: 2nd Feb 2019, 20:35 -
1080p 60fps mp4 capture device...that uses device CPU not PCs CPU?
By Blackout in forum Capturing and VCRReplies: 36Last Post: 11th Sep 2018, 12:40 -
severals hours of rendering can damage an intel cpu with bundle little fan?
By rama in forum ComputerReplies: 16Last Post: 14th May 2017, 12:51 -
AMD HD7870 Fan speed throttline
By pchan in forum ComputerReplies: 20Last Post: 10th Jul 2016, 19:49 -
PotPlayer - Fan speed when paused?
By vdoep86 in forum Software PlayingReplies: 3Last Post: 11th Apr 2015, 04:52
