  1. Hello All,
    Good Day!
    Im looking for your help and suggestion how to get started with CC conversion from .xml to .vtt
    We are having lots of flash files where we have xml to vtt during a project migration. I tried with many online tools most dont have solution for this.
    Could you please help me how to start on this. Suggest me any tools/online converters which can do this job for me.
    Sumanth
    Aug 2006
    Did you try Subtitle Edit yet? It isn't an online tool but it is free and appears to be able to perform the necessary conversion
  3. Notice Subtitle Edit has a batch conversion both in the GUI as well as a CLI.
  4. Originally Posted by Sumanth46 View Post
    Can you post a source/destination example?
  5. Originally Posted by video.baba View Post
    --- here is the sample code format
    <captions>
    <caption time_in="0.64" time_out="4.74" action=""><![CDATA[Line 1]]></caption>
    <caption time_in="4.75" time_out="8.05" action=""><![CDATA[line 2]]></caption>
    <captions>
  6. Originally Posted by videobruger View Post
    i have tried Subtitle Edit. But the generated output is not properly encoded.
    1) Time stamps are randomly generated.
    2)its even generating <caption> tag
    any settings need to be updated?
    Aug 2006
    Maybe. I don't know anything about the various xml-based subtitle formats currently in use or how to distinguish between them but Subtitle Edit lists quite a few different types under the "Format" drop-down list. Some use the file extension "xml" and some don't. If you don't know what type of xml formatting is used for your subs, you should try to find out, and use the matching entry on the "Format" list, if there is one. Your choice changes how the contents of each file are interpreted.
    Jul 2011
    Denmark
    @ Sumanth46: Subtitle Edit does not know this format. Could you supply a source sample where a single subtitle has two lines?
    Latest beta (portable version) should help you: https://github.com/SubtitleEdit/subtitleedit/releases/download/3.5.9/SubtitleEditBeta.zip
