Hi.
Have some audio files (.aac) that is downloaded from youtube via an firefox extension.
There seems to be two types of aac files, based on the output from ffmpeg -i command.
Example 1 (most common)
Example 2Code:ffmpeg -i 'Track 1.aac' -hide_banner [aac @ 0x55a6ce64db00] Estimating duration from bitrate, this may be inaccurate Input #0, aac, from 'Track 1.aac': Duration: 00:05:42.05, bitrate: 122 kb/s Stream #0:0: Audio: aac (LC), 44100 Hz, stereo, fltp, 122 kb/s At least one output file must be specified
It seems that one file have metadata while the other have none. Is there other differences?Code:ffmpeg -i 'Track 2.aac' -hide_banner Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Track 2.aac': Metadata: major_brand : dash minor_version : 0 compatible_brands: iso6mp41 creation_time : 2018-09-17T20:30:35.000000Z Duration: 00:07:54.80, start: 0.000000, bitrate: 127 kb/s Stream #0:0(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 2 kb/s (default) Metadata: creation_time : 2018-09-17T20:30:35.000000Z handler_name : SoundHandler At least one output file must be specified
I think that too.
Mediainfo for Track 1
Code:<?xml version="1.0" encoding="UTF-8"?> <MediaInfo xmlns="https://mediaarea.net/mediainfo" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="https://mediaarea.net/mediainfo https://mediaarea.net/mediainfo/mediainfo_2_0.xsd" version="2.0"> <creatingLibrary version="19.07" url="https://mediaarea.net/MediaInfo">MediaInfoLib</creatingLibrary> <media ref="/home/prototype/Desktop/music/Track 1.aac"> <track type="General"> <AudioCount>1</AudioCount> <FileExtension>aac</FileExtension> <Format>ADTS</Format> <FileSize>5258855</FileSize> <OverallBitRate_Mode>VBR</OverallBitRate_Mode> <StreamSize>0</StreamSize> <File_Modified_Date>UTC 2018-11-01 17:14:29</File_Modified_Date> <File_Modified_Date_Local>2018-11-01 18:14:29</File_Modified_Date_Local> </track> <track type="Audio"> <Format>AAC</Format> <Format_Version>4</Format_Version> <Format_AdditionalFeatures>LC</Format_AdditionalFeatures> <CodecID>2</CodecID> <BitRate_Mode>VBR</BitRate_Mode> <Channels>2</Channels> <ChannelPositions>Front: L R</ChannelPositions> <ChannelLayout>L R</ChannelLayout> <SamplesPerFrame>1024</SamplesPerFrame> <SamplingRate>44100</SamplingRate> <FrameRate>43.066</FrameRate> <Compression_Mode>Lossy</Compression_Mode> <StreamSize>5258855</StreamSize> <StreamSize_Proportion>1.00000</StreamSize_Proportion> </track> </media> </MediaInfo>
And for Track 2
Code:<?xml version="1.0" encoding="UTF-8"?> <MediaInfo xmlns="https://mediaarea.net/mediainfo" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="https://mediaarea.net/mediainfo https://mediaarea.net/mediainfo/mediainfo_2_0.xsd" version="2.0"> <creatingLibrary version="19.07" url="https://mediaarea.net/MediaInfo">MediaInfoLib</creatingLibrary> <media ref="/home/prototype/Desktop/music/Track 2.aac"> <track type="General"> <AudioCount>1</AudioCount> <FileExtension>aac</FileExtension> <Format>dash</Format> <CodecID>dash</CodecID> <CodecID_Compatible>iso6/mp41</CodecID_Compatible> <FileSize>7541674</FileSize> <Duration>474.802</Duration> <OverallBitRate>127071</OverallBitRate> <StreamSize>87984</StreamSize> <HeaderSize>3020</HeaderSize> <DataSize>157378</DataSize> <FooterSize>7381276</FooterSize> <IsStreamable>Yes</IsStreamable> <Encoded_Date>UTC 2018-09-17 20:30:35</Encoded_Date> <Tagged_Date>UTC 2018-09-17 20:30:35</Tagged_Date> <File_Modified_Date>UTC 2018-10-25 22:04:53</File_Modified_Date> <File_Modified_Date_Local>2018-10-26 00:04:53</File_Modified_Date_Local> </track> <track type="Audio"> <StreamOrder>0</StreamOrder> <ID>1</ID> <Format>AAC</Format> <Format_AdditionalFeatures>LC</Format_AdditionalFeatures> <CodecID>mp4a-40-2</CodecID> <Duration>474.802</Duration> <BitRate>125588</BitRate> <Channels>2</Channels> <ChannelPositions>Front: L R</ChannelPositions> <ChannelLayout>L R</ChannelLayout> <SamplesPerFrame>1024</SamplesPerFrame> <SamplingRate>44100</SamplingRate> <SamplingCount>20938768</SamplingCount> <FrameRate>43.066</FrameRate> <FrameCount>20448</FrameCount> <Compression_Mode>Lossy</Compression_Mode> <StreamSize>7453690</StreamSize> <StreamSize_Proportion>0.98833</StreamSize_Proportion> <Language>en</Language> <Encoded_Date>UTC 2018-09-17 20:30:35</Encoded_Date> <Tagged_Date>UTC 2018-09-17 20:30:35</Tagged_Date> </track> </media> </MediaInfo> -
I choosed xml because it is more detailed than text mode and I assumed that was the best (i.e. most informative) choice.
But hey, I can always post the text info in aditional: -
Here it is:
Text version for track 1
Code:General Complete name : /home/prototype/Desktop/music/Track 1.aac Format : ADTS Format/Info : Audio Data Transport Stream File size : 5.02 MiB Overall bit rate mode : Variable Audio Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Format version : Version 4 Codec ID : 2 Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 5.02 MiB (100%)
Text version for track 2
Code:General Complete name : /home/prototype/Desktop/music/Track 2.aac Format : dash Codec ID : dash (iso6/mp41) File size : 7.19 MiB Duration : 7 min 54 s Overall bit rate : 127 kb/s Encoded date : UTC 2018-09-17 20:30:35 Tagged date : UTC 2018-09-17 20:30:35 Audio ID : 1 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 7 min 54 s Bit rate : 126 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 7.11 MiB (99%) Language : English Encoded date : UTC 2018-09-17 20:30:35 Tagged date : UTC 2018-09-17 20:30:35
Converting to AAC 5.1 / 7.1 with ffmpeg changes channel layout
By vash1 in forum Newbie / General discussionsReplies: 68Last Post: 27th May 2025, 12:20 -
ffmpeg: how to encode AAC @ CBR instead of VBR?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2018, 16:25 -
Handbrake without FDK-AAC, new FFMPEG AAC encoder viable alternative?
By jaggy in forum Video ConversionReplies: 15Last Post: 27th Apr 2017, 11:31 -
Whats the difference between AAC (avcodec) and AAC Passthru in Handbrake?
By Nazomon in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2014, 17:49 -
FFmpeg's MP4 is not AAC?
By Djard in forum AudioReplies: 8Last Post: 20th Oct 2014, 20:53
