Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Aug 2019
    San Diego
    I am looking for a simple solution to taking thousands of videos and adding a 6 second open to each one, with the fewest steps. I do not want to have to manually export each video. I'm looking to do a batch of videos all at the same time.
  2. Well, it should be doable with ffmpeg and a simple batch script... Is the opening sequence already ready, and is it in the same format as you intend the output to be ? What format is this ? (Video codec, audio codec, container, framerate, sample rate... pretty much everything has to match.)
    Aug 2019
    San Diego
    Thanks for the post. And funny, that was the solution we are implementing. I hired a programmer from Turkey who is creating a custom interface with a Youtube API to bulk upload hundreds of videos.
