Hi, new to the forum and mostly a newbie to ffmpeg.
I perform this quite simple encoding test using different input files: I choose x265, crf 28, and mkv as output container.
Using the new 4.1.4 ffmpeg version the resulting files show up in MediaInfo as "Color Range: Limited".
Using previous versions of ffmpeg, they don't.
Can someone please explain what's changed in the new version (and maybe why)?
Results 1 to 13 of 13
This is one of the reasons I'm not a big fan of ffmpeg as my main encoder, they change things, you need to have a programmer lever to understand what is going on, etc. From what I understand from the x264 encoder, you can change that with "--range" set to "pc" (--range pc) will give the result you want.
Thanks for your answer, jagabo
That was my suspicion: the only change being that new version is flagging it properly now... but I can't find any differences between old/new output files using ffprobe, so where's the new flag?
Maybe ffprobe can't see it?
Or maybe ffprobe could always see it but the flag is written now in a way MediaInfo can finally detect? -
It may be related to removing uncertainty in ffmpeg:
https://git.ffmpeg.org/gitweb/ffmpeg.git?a=search&h=HEAD&st=commit&s=Color+Range
particularly this: https://git.ffmpeg.org/gitweb/ffmpeg.git/commit/cb78d14cf9b5ab59b4a9177f390f5e1abff58644
or similar changes in x265 code (to remove situation where unspecified\uncertain colour range is present in video).
One of basic rules in good programming and in good HW design is to remove uninitialized/unspecified data and/or states. -
My input files are most probably "limited color range", too. They're xvid-avis and x264-mkvs. MediaInfo don't report them as limited, though.
I have a DVD-to-xvid and a BluRay-to-x264 encoded files from a year ago. They don't show up as limited range but as far as I understand, at least the DVD should be. So MediaInfo isn't showing all the info properly, I suspect, and I don't know what other tool to use to get a confirmation on this.
So... I can't say for sure if ffmpeg is encoding the file differently or, as jagabo said, it is only flagging it properly now. -
That's another possibility I've tried to confirm searching... but those commits seem to be pre-4.1.3 release... and I'm seeing this change in behaviour between versions 4.1.3 and 4.1.4.
(I mean... encoding with 4.1.3 > no "limited range" found by MediaInfo, but enconding with latest 4.1.4 > "limited range" reported) -
Check source for x265 - x265 is external library not maintained by ffmpeg developers. Changes may be introduced in x265 and simply derived in ffmpeg as part of libx265. Also another explanation is that Mediainfo began to report colour quantization range - check your source pre and post change in some H.265 analyzer - VUI video_signal_type_present_flag & video_full_range_flag
Check this slightly outdated list:
https://hdfpga.blogspot.com/2013/02/hevch265-analysis-tools.html
Don't forget about Intel https://software.intel.com/en-us/video-pro-analyzer 9seem it was Intel product)
and there is few other very similar projects
https://sourceforge.net/projects/gtilhevcanalyzer/ -
Thanks for your help, pandy. I'll check those programs and learn quite bit more.
It is clear that, at some point, you need to stop dong things just following a tutorial and start learning the basics carefully to get a better idea about what you're doing and why, and that's where I seem to be now with my simple video processing needs. -
Encoder can select range flag or not.
But it doesn't matter what is set or not, encoder would encode in the same manner, using your YUV values in video and getting new YUV video. YUV values are not changed to limited or full. The only way to change YUV values would be after a conversion. But that is something else.
That flag is only used and comes alive if video is converted to RGB on screen. Videoplayers look for that flag. Or they should. If there is no flag, most likely video player would assume limited YUV as input and full RGB as output.
FFMpeg "non-monotonous DTS in output stream" error
By CursedLemon in forum Video ConversionReplies: 4Last Post: 26th Aug 2018, 10:56 -
Use "Line in" or "Microphone" jack as audio output.
By DonSeenu in forum AudioReplies: 3Last Post: 14th May 2018, 04:23 -
ffmpeg "unsuitable output format" error
By arthurm in forum Video ConversionReplies: 10Last Post: 17th Sep 2015, 11:04 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
Why Playing Menus in Blu-Rays are "Limited" to Paid Programs Mostly?
By devilcoelhodog in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2014, 19:13
