i have a pinical dc10 plus capture card , and i have been capturing at 720 x 576 at 6meg / sec data rate , and im getting a few frame drops , but they usually seem to be related to timing info on the tapes being a bit "out" if i capture from a live source , i usually get few if any droped frames , but not from tape. where can i get a TBC from and roughly how much should it cost ? , and will it solve my problems ?
thanks all.
p4 1.7
512 meg ram
biostar mainboard
1 x ibm 7200 rpm 40 gig hdd
1 x seagate 5600 rpm 40 gig hdd
64 meg nvidia geforce 2 mx m400 agp video card
creative 128 sound card.
Sometimes it's just the other way around.With TBC on, I get more dropped frames than without.I'm using a copy enhancer from DATAVIDEO nnow, which amplifies the video signal and also takes care of MacroVision distortion.
i usually only get dropped frames when there is some white noise on the screen. or if there is somthing wrong with the tape. if i capture straight from my video cam (which has a tbc built in) i get 0 dropped frames every time. but i dont do much of this. mainly capture from vhs.
Time Base Correctors
By josel in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2010, 13:01 -
What does a time based corrector actually correct?
By Rudyard in forum Capturing and VCRReplies: 15Last Post: 26th May 2010, 07:45 -
Time Base Corrector Information
By Sprout in forum Video ConversionReplies: 4Last Post: 11th Apr 2010, 04:33 -
Do I need a Time Base Corrector? If so, which do I get?
By Smack2k in forum Capturing and VCRReplies: 3Last Post: 11th Jul 2008, 11:41 -
Anyone try the TV One 1T-TBC time base corrector yet?
By heman31 in forum RestorationReplies: 0Last Post: 15th Sep 2007, 18:20
