  1. I know Avisynth function parameters can have default values. For instance, the Subtitle filter can be used in the short form
    Subtitle(clip,"text")
    without giving any additional arguments (x, y...) because they already have default values.
    But I do not know how to define default values for my own functions. I have read the guides, searched the Web, etc. but couldn't find anything that works for me.
    As an example, say we have the following simple function, which adds or subtracts 2 numbers, depending on the conditional parameter Plus.
    Function PlusMinus(int n1, int n2, bool Plus)
    result = (Plus==True) ? n1+n2 : n1-n2
    return result
    How do we define "Plus" to be True as default?
    So that we can use
    n3 = PlusMinus(n1, n2)
    as the short form of
    n3 = PlusMinus(n1, n2, True)
  2. Originally Posted by Zeppo View Post
    Plus = default(Plus, true)
    Thank you.
    Do you mean coding the function like this?
    return result
    Because it isn't working
    AviSource("J:\01.avi").Trim (525, PlusMinus(525, 100, True)) gives no error
    AviSource("J:\01.avi").Trim (525, PlusMinus(525, 100)) gives "Invalid arguments to function PlusMinus"
  3. I have found this work
    Function PlusMinus(int n1, int n2, bool "Plus")
    return result
    ie, defining the parameter as bool "Plus", instead of just bool Plus
    The quotation marks did the trick here.
  4. Yes, the argument needs to be in quotes for default() to work.
  5. Originally Posted by CoralMan View Post
    This will work:
    AviSource("J:\01.avi").Trim (525, PlusMinus(n1 = 525, n2 = 100))
    If you omit one or more arguments you have to use named parameters.
