Rough Preview of the Sample
The sample serves as an adequate example for a demonstration of the subject:
Consecutive duplicate frames for 3:32.56 --> 5:04 (the end), usual content for the rest of the video.
The term "last frame" below means: A single frame from those consecutive duplicates during 3:32.56 --> 5:04 in the above sample.
Below are some file sizes pertaining to the demo, which may shed some light on the subject:
(Tool: FFmpeg 4.1.4)
#Lossless (rgb24), keyint=infinite
30126520439 Bytes:
30126201980 Bytes:Code:ffmpeg -i INPUT_rgb24 -an -c:v libx264rgb -preset placebo -qp 0 -x264-params "keyint=infinite:no-deblock=1" "Lossless_keyint=infinite.mkv"
30126520439-30126201980 = 318459 BytesCode:ffmpeg -i INPUT_rgb24_TRIM -an -c:v libx264rgb -preset placebo -qp 0 -x264-params "keyint=infinite:no-deblock=1" "TRIM_Lossless_keyint=infinite.mkv"
#Lossless (rgb24), keyint=15
#Note: Missing the last frame in the TRIM.
31362559339 Bytes:
30730918362 Bytes:Code:ffmpeg -i INPUT_rgb24 -an -c:v libx264rgb -preset placebo -qp 0 -x264-params "keyint=15:no-deblock=1" "Lossless_keyint=15.mkv"
31362559339-(30730918362+7683697) = 623957280 BytesCode:ffmpeg -i !INPUT_rgb24_TRIM -an -c:v libx264rgb -preset placebo -qp 0 -x264-params "keyint=15:no-deblock=1" "!TRIM_Lossless_keyint=15.mkv"
#PNG (last frame)
7683697 Bytes:
(workaround as of `-sseof 0` failed to work...)Code:ffmpeg -ss 3:32.56 -i INPUT_rgb24_TRIM -compression_level 10 -pred mixed -pix_fmt rgb24 -sws_flags spline+accurate_rnd+full_chroma_int "PNG.png"
#Near-Lossless (yuv420p), keyint=150
1272631389 Bytes:
1229081917 Bytes:Code:ffmpeg -i INPUT_rgb24 -an -c:v libx264 -preset placebo -crf 19 -x264-params "level=5.1:keyint=150:psy-rd=2,1" -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 "Near-Lossless_keyint=150.mp4"
1272631389-1229081917 = 43549472 BytesCode:ffmpeg -i INPUT_rgb24_TRIM -an -c:v libx264 -preset placebo -crf 19 -x264-params "level=5.1:keyint=150:psy-rd=2,1" -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 "TRIM_Near-Lossless_keyint=150.mp4"
1637464899 Bytes:
1377592853 Bytes:Code:ffmpeg -i INPUT_rgb24 -an -c:v libx264 -preset placebo -crf 19 -x264-params "level=5.1:keyint=15:psy-rd=2,1" -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 "Near-Lossless_keyint=15.mp4"
1637464899-1377592853 = 259872046 BytesCode:ffmpeg -i INPUT_rgb24_TRIM -an -c:v libx264 -preset placebo -crf 19 -x264-params "level=5.1:keyint=15:psy-rd=2,1" -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 "TRIM_Near-Lossless_keyint=15.mp4"
Note
The "last frame"s are at 15 FPS in the Lossless, but at 30 FPS in the Near-Lossless... (thanks to my inappropriate handling, imposing `-vsync vfr` should will fix this... haven't tried though)
Though it might not make any significant difference at all... (VFR, CFR can be essentially the same thing... with only the timestamps differ)
But who knows?..
Sadly... that's not the case. (which means, that cfr/vfr in the case will have an obvious impact on the output size of materials with such characteristics)
Conclusion
Absurd, isn't it?
Bewildered too at first... But then soon sort of understood its design language behind this seeming absurdity.
(To be continued...)
Off-Topic
And if you wouldn't mind... please do me a favor:
How to trick the mpdecimate to drop those exactly identical frames but not the nearly identical ones?
...To save me a few minutes' blind testing (as you see in the docs... meh).
Like this:
Code:-vf "mpdecimate=0:0:0"
Further Off-Topic
Be careful with the `-vsync cfr` option (...and take care that the option can be inexplicitly enabled), it may alter the playback experience by duplicating the wrong frames.
When using `mpdecimate` excessively (like having the whole 3:32.56 --> 5:04 in the aforementioned sample as a single frame...), the output tends to report a wrong duration, while the PTS seemed to remain correct. (which means the playback progress could look like: 00:05:04.00 / 00:03:32.96)
Note: I added (must add?) a single "Black Screen" frame (or whatever frames) here right after the last frame just for the testing.
* For the "duration" of frames may not actually exist...
Take extra caution when having the framerate below 15 FPS in any part of the video.
Anything below 15 FPS seems to have serious playback issues in quite an amount of players... (problematic seeking, frozen video, etc.)
* More accurately, VLC-like players. (and likely a VLC exclusive long time known issue...)
Reference:
https://forum.videolan.org/viewtopic.php?t=107770
https://forum.videolan.org/viewtopic.php?t=123887
https://stackoverflow.com/a/39213083
Similar behavior also in VP9.
Check the output of `youtube-dl`:
Code:C:\>youtube-dl -F https://www.youtube.com/watch?v=8fyTbI4TIS0 [youtube] 8fyTbI4TIS0: Downloading webpage [youtube] 8fyTbI4TIS0: Downloading video info webpage [info] Available formats for 8fyTbI4TIS0: format code extension resolution note 249 webm audio only DASH audio 64k , opus @ 50k, 1.61MiB 250 webm audio only DASH audio 83k , opus @ 70k, 2.11MiB 140 m4a audio only DASH audio 130k , m4a_dash container, mp4a.40.2@128k, 3.65MiB 251 webm audio only DASH audio 162k , opus @160k, 4.16MiB 160 mp4 256x108 144p 31k , avc1.4d400b, 15fps, video only, 567.07KiB 278 webm 256x108 144p 45k , webm container, vp9, 15fps, video only, 696.57KiB 133 mp4 426x180 240p 68k , avc1.4d400c, 15fps, video only, 1.21MiB 242 webm 426x180 240p 83k , vp9, 15fps, video only, 1.07MiB 243 webm 640x270 360p 122k , vp9, 15fps, video only, 1.59MiB 134 mp4 640x270 360p 160k , avc1.4d4015, 15fps, video only, 2.22MiB 244 webm 854x360 480p 186k , vp9, 15fps, video only, 2.71MiB 135 mp4 854x360 480p 276k , avc1.4d4016, 15fps, video only, 3.82MiB 247 webm 1280x540 720p 319k , vp9, 15fps, video only, 4.21MiB 136 mp4 1280x540 720p 523k , avc1.4d401f, 15fps, video only, 6.80MiB 248 webm 1920x810 1080p 655k , vp9, 15fps, video only, 8.57MiB 271 webm 2560x1080 1440p 900k , vp9, 15fps, video only, 14.08MiB 137 mp4 1920x810 1080p 1091k , avc1.640028, 15fps, video only, 11.08MiB 313 webm 3840x1620 2160p 1749k , vp9, 15fps, video only, 28.65MiB 272 webm 5120x2160 2880p 5291k , vp9, 15fps, video only, 51.15MiB 18 mp4 640x270 medium 199k , avc1.42001E, mp4a.40.2@ 96k (44100Hz), 5.63MiB (best)
The original file (what I threw at YouTube):
The output ("1.mkv") is of 23.37 MiB, in which 18.88 MiB is the FLAC audio stream... The video stream is of only 4.48 MiB.Code:ffmpeg -loop 1 -i "Entrepreneurship.png" -i "1.flac" -c:a copy -c:v libx264 -r 15 -vframes 3548 -preset placebo -qp 0 -x264-params "level=5.1:keyint=infinite:no-deblock=1" -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 "1.mkv"
Strange... it ends in audio truncation near the EOF (End of File).
Has to be done in a separated manner:Code:C:\>ffprobe "1.mkv" ffprobe version 4.1.4 Copyright (c) 2007-2019 the FFmpeg developers built with gcc 9.1.1 (GCC) 20190716 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth libavutil 56. 22.100 / 56. 22.100 libavcodec 58. 35.100 / 58. 35.100 libavformat 58. 20.100 / 58. 20.100 libavdevice 58. 5.100 / 58. 5.100 libavfilter 7. 40.101 / 7. 40.101 libswscale 5. 3.100 / 5. 3.100 libswresample 3. 3.100 / 3. 3.100 libpostproc 55. 3.100 / 55. 3.100 Input #0, matroska,webm, from '1.mkv': Metadata: ENCODER : Lavf58.20.100 Duration: 00:03:56.53, start: 0.000000, bitrate: 822 kb/s Stream #0:0: Video: h264 (High 4:4:4 Predictive), yuv420p(tv, bt470bg/bt470bg/smpte170m, progressive), 5120x2160, 15 fps, 15 tbr, 1k tbn, 30 tbc (default) Metadata: ENCODER : Lavc58.35.100 libx264 DURATION : 00:03:56.534000000 Stream #0:1: Audio: flac, 48000 Hz, stereo, s16 (default) Metadata: DURATION : 00:03:54.912000000 C:\>ffprobe -hide_banner "1.flac" Input #0, flac, from '1.flac': Metadata: ENCODER : Lavf58.20.100 Duration: 00:03:56.57, start: 0.000000, bitrate: 669 kb/s Stream #0:0: Audio: flac, 48000 Hz, stereo, s16
(...in order to have things worked normally)
And similar things also for FFmpeg 4.2...Code:ffmpeg -loop 1 -i "Entrepreneurship.png" -c:v libx264 -r 15 -vframes 3548 -preset placebo -qp 0 -x264-params "level=5.1:keyint=infinite:no-deblock=1" -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 "TEMP_v.mkv" ffmpeg -i "TEMP_v.mkv" -i "1.flac" -c copy "1.mkv"
Ticket of the Issue
* FYI, the best command for preparing music uploading for YouTube is:
(taken the above case as example)
Code:ffmpeg -i "Entrepreneurship.png" -i "1.flac" -c:a copy -c:v libx264 -r 1/236.571542 -preset placebo -qp 0 -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int+bitexact -vsync vfr -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 -flags +bitexact -fflags +bitexact -map_metadata -1 "1.mkv"
looking at the definition you linked to:How to trick the mpdecimate to drop those exactly identical frames but not the nearly identical ones?
-> have you tried setting low, high and frac to zero? Sounds to me like the filter then should drop all consecutive bit identical frames and only those.Drop frames that do not differ greatly from the previous frame in order to reduce frame rate.
The main use of this filter is for very-low-bitrate encoding (e.g. streaming over dialup modem), but it could in theory be used for fixing movies that were inverse-telecined incorrectly.
A description of the accepted options follows.
max
Set the maximum number of consecutive frames which can be dropped (if positive), or the minimum interval between dropped frames (if negative). If the value is 0, the frame is dropped disregarding the number of previous sequentially dropped frames.
Default value is 0.
hi
lo
frac
Set the dropping threshold values.
Values for hi and lo are for 8x8 pixel blocks and represent actual pixel value differences, so a threshold of 64 corresponds to 1 unit of difference for each pixel, or the same spread out differently over the block.
A frame is a candidate for dropping if no 8x8 blocks differ by more than a threshold of hi, and if no more than frac blocks (1 meaning the whole image) differ by more than a threshold of lo.
Default value for hi is 64*12, default value for lo is 64*5, and default value for frac is 0.33.users currently on my ignore list: deadrats, Stears555, marcorocchini -
While I don't understand what you are trying to do, the usual tool I use for finding and then eliminating duplicate fields or duplicate frames is the TFM/TDecimate combination. It has a myriad of settings that let you find and then eliminate duplicates. However, it is generally best suited for situations where the duplicates come at fairly regular intervals, such as the dups found in telecined material. However, I have used it for many other situations where the pattern of duplicates is obscure or non-existent.
An alternative is to simply construct your own duplicate detection filter using built-in AVISynth functions, such as the YDifference functions, or some of the functions found in RTStats and similar libraries. This is actually quite easy to do IF your duplicates are, in fact, 100.0000% identical. When this is the case, even the simple YDifference function will return 0.000, whereas any other set of adjacent frames will return a non-zero result. You then either output the frame numbers of the duplicate frames and feed those to a decimation filter, often done as a second step, or do more work and try to decimate them in one pass.
Just search this forum for "YDifferenceFromPrevious" or "YDifferenceToNext". If you search on my user name you'll find dozens of scripts that show how to use this in conjunction with conditional logic to take some action when this metric differs greatly from the metrics from adjacent frames; when it blows up; or when, as in this case, goes to a mathematically pure zero. -
You're so right! ...Except that `frac` doesn't matter at all. (in this case... well, technically it does, though likely unnoticeable)
According to the source, and an answer on Stack Exchange:
As mpdecimate explains, one 8x8 block where the sum of differences exceeds `hi` will result in an output frame (no drop). Same when more than `frac` fraction of the 8x8 blocks have more than `lo` difference. So if there's a blinking cursor, that will trigger `hi` every time unless you crank it all the way up and just depend on `lo`.Last edited by gdgsdg123; 3rd Aug 2019 at 18:53.
Replace random duplicate frames with black frames (AVISYNTH)
By benzio in forum EditingReplies: 7Last Post: 31st Jan 2018, 16:43 -
Can you remove duplicate frames without re-encoding?
By VideoFanatic in forum RestorationReplies: 3Last Post: 5th Jul 2017, 14:44 -
AVISynth / sRestore not removing duplicate frames
By bvdd in forum Video ConversionReplies: 4Last Post: 23rd Nov 2015, 07:08 -
Removing duplicate frames
By Colek in forum Video ConversionReplies: 7Last Post: 9th Oct 2015, 12:40 -
Script to detect duplicate frames?
By kieranvyas in forum EditingReplies: 30Last Post: 22nd Aug 2015, 20:01
