    Sep 2014
    Rome
    Hi
    can I ask you which software was used to capture video in this video ?
    would like to know because the software can show left or right click mouse and i guess it does emulate the mouse click
    need it to create a short tutorial for a friend
    the video is here
    thanks
    https://youtu.be/Gm2bw7OUP_w?t=110
    canada
    Youtube re-encodes the video files so unless there's anything already imprinted on the video there's no way you can find who did the video.
    Sep 2014
    Rome
    Hi johns
    so it's hard to find out the software used
    that's a pitty just because i would like to use the same software
    do you know a free software or trial/paid that let me record and it does show when i click the left or right mouse button ?
    thanks
  4. Member DB83's Avatar
    Jul 2007
    Practically all screen-capture software will display the mouse and record any sound produced on the desktop.
    And Windows itself has sounds options that will produce a noise on mouse clicks. It may also have some tracking feature to highlight the the actual click.
    So to recap, it is not the capture software it is settings within windows itself.
    BTW I like many would find a continuous mouse-click noise pretty annoying (as per the comments in this video)
    Jan 2016
    The best person to ask is the youtube member who posted the video, Just drop a comment and I'm pretty sure he will get back to you.
  6. Capturing Memories dellsam34's Avatar
    Jan 2016
    It has nothing to do with youtube he is asking about the software used to capture the desktop, Only the person who made the video knows or someone who used it already.
  7. camtasia - it has options for r/l click viewing and audio options . It records the data during the session (r/l clicks, mouse position) and you have options to change the effect/appearance/sound in their editor
