Having issues with nvenc which used to work on this systems. ffmpeg appears to complete without errors but never does the encoding and the output is an empty file. I recently updated the driver for gpu too.
Code:ffmpeg -loglevel debug -i output.ts -c:a copy -c:v h264_nvenc -max_muxing_queue_size 1024 -y out.mp4 ffmpeg version N-94391-g052d41377a Copyright (c) 2000-2019 the FFmpeg developers built with gcc 9.1.1 (GCC) 20190716 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt libavutil 56. 32.100 / 56. 32.100 libavcodec 58. 55.100 / 58. 55.100 libavformat 58. 30.100 / 58. 30.100 libavdevice 58. 9.100 / 58. 9.100 libavfilter 7. 58.100 / 7. 58.100 libswscale 5. 6.100 / 5. 6.100 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 Splitting the commandline. Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'. Reading option '-i' ... matched as input url with argument 'output.ts'. Reading option '-c:a' ... matched as option 'c' (codec name) with argument 'copy'. Reading option '-c:v' ... matched as option 'c' (codec name) with argument 'h264_nvenc'. Reading option '-max_muxing_queue_size' ... matched as option 'max_muxing_queue_size' (maximum number of packets that can be buffered while waiting for all streams to initialize) with argument '1024'. Reading option '-y' ... matched as option 'y' (overwrite output files) with argument '1'. Reading option 'out.mp4' ... matched as output url. Finished splitting the commandline. Parsing a group of options: global . Applying option loglevel (set logging level) with argument debug. Applying option y (overwrite output files) with argument 1. Successfully parsed a group of options. Parsing a group of options: input url output.ts. Successfully parsed a group of options. Opening an input file: output.ts. [NULL @ 000001c6a0c0a600] Opening 'output.ts' for reading [file @ 000001c6a0c0b700] Setting default whitelist 'file,crypto' [mpegts @ 000001c6a0c0a600] Format mpegts probed with size=2048 and score=50 [mpegts @ 000001c6a0c0a600] stream=0 stream_type=2 pid=100 prog_reg_desc= [mpegts @ 000001c6a0c0a600] stream=1 stream_type=81 pid=101 prog_reg_desc= [mpegts @ 000001c6a0c0a600] Before avformat_find_stream_info() pos: 0 bytes read:32768 seeks:0 nb_streams:2 [mpeg2video @ 000001c6a0c0b840] Format yuv420p chosen by get_format(). [mpegts @ 000001c6a0c0a600] Probe buffer size limit of 5000000 bytes reached [mpegts @ 000001c6a0c0a600] After avformat_find_stream_info() pos: 0 bytes read:6049936 seeks:2 frames:132 Input #0, mpegts, from 'output.ts': Duration: 00:00:29.33, start: 1.400000, bitrate: 21158 kb/s Program 1 Metadata: service_name : Service01 service_provider: FFmpeg Stream #0:0[0x100], 61, 1/90000: Video: mpeg2video (Main), 1 reference frame ([2][0][0][0] / 0x0002), yuv420p(tv, top first, left), 1920x1080 [SAR 1:1 DAR 16:9], 0/1, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0x101](eng), 71, 1/90000: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 384 kb/s Successfully opened the file. Parsing a group of options: output url out.mp4. Applying option c:a (codec name) with argument copy. Applying option c:v (codec name) with argument h264_nvenc. Applying option max_muxing_queue_size (maximum number of packets that can be buffered while waiting for all streams to initialize) with argument 1024. Successfully parsed a group of options. Opening an output file: out.mp4. [file @ 000001c6a0c11bc0] Setting default whitelist 'file,crypto' Successfully opened the file. detected 8 logical cores Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (h264_nvenc)) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help cur_dts is invalid st:0 (0) [init:0 i_done:0 finish:0] (this is harmless if it occurs once at the start per stream) Last message repeated 9 times [mpeg2video @ 000001c6a1461240] Format yuv420p chosen by get_format(). cur_dts is invalid st:0 (0) [init:0 i_done:0 finish:0] (this is harmless if it occurs once at the start per stream) Last message repeated 1 times [mpeg2video @ 000001c6a1461240] Skipping B slice due to open GOP Last message repeated 67 times cur_dts is invalid st:0 (0) [init:0 i_done:0 finish:0] (this is harmless if it occurs once at the start per stream) Last message repeated 1 times [mpeg2video @ 000001c6a1461240] Skipping B slice due to open GOP Last message repeated 67 times cur_dts is invalid st:0 (0) [init:0 i_done:0 finish:0] (this is harmless if it occurs once at the start per stream) Last message repeated 1 times [graph 0 input from stream 0:0 @ 000001c6a0ca0140] Setting 'video_size' to value '1920x1080' [graph 0 input from stream 0:0 @ 000001c6a0ca0140] Setting 'pix_fmt' to value '0' [graph 0 input from stream 0:0 @ 000001c6a0ca0140] Setting 'time_base' to value '1/90000' [graph 0 input from stream 0:0 @ 000001c6a0ca0140] Setting 'pixel_aspect' to value '1/1' [graph 0 input from stream 0:0 @ 000001c6a0ca0140] Setting 'sws_param' to value 'flags=2' [graph 0 input from stream 0:0 @ 000001c6a0ca0140] Setting 'frame_rate' to value '30000/1001' [graph 0 input from stream 0:0 @ 000001c6a0ca0140] w:1920 h:1080 pixfmt:yuv420p tb:1/90000 fr:30000/1001 sar:1/1 sws_param:flags=2 [format @ 000001c6a0c74900] Setting 'pix_fmts' to value 'yuv420p|nv12|p010le|yuv444p|p016le|yuv444p16le|bgr0|rgb0|cuda|d3d11' [AVFilterGraph @ 000001c6a0c6c080] query_formats: 4 queried, 3 merged, 0 already done, 0 delayed [h264_nvenc @ 000001c6a0c0ff00] Loaded lib: nvcuda.dll [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuInit [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDeviceGetCount [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDeviceGet [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDeviceGetAttribute [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDeviceGetName [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDeviceComputeCapability [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuCtxCreate_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuCtxSetLimit [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuCtxPushCurrent_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuCtxPopCurrent_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuCtxDestroy_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMemAlloc_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMemAllocPitch_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMemsetD8Async [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMemFree_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMemcpy2D_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMemcpy2DAsync_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGetErrorName [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGetErrorString [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuStreamCreate [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuStreamQuery [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuStreamSynchronize [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuStreamDestroy_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuStreamAddCallback [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuEventCreate [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuEventDestroy_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuEventSynchronize [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuEventQuery [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuEventRecord [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuLaunchKernel [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuModuleLoadData [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuModuleUnload [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuModuleGetFunction [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuTexObjectCreate [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuTexObjectDestroy [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGLGetDevices_v2 [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGraphicsGLRegisterImage [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGraphicsUnregisterResource [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGraphicsMapResources [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGraphicsUnmapResources [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuGraphicsSubResourceGetMappedArray [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDeviceGetUuid [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuImportExternalMemory [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDestroyExternalMemory [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuExternalMemoryGetMappedBuffer [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuExternalMemoryGetMappedMipmappedArray [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMipmappedArrayGetLevel [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuMipmappedArrayDestroy [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuImportExternalSemaphore [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuDestroyExternalSemaphore [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuSignalExternalSemaphoresAsync [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: cuWaitExternalSemaphoresAsync [h264_nvenc @ 000001c6a0c0ff00] Loaded lib: nvEncodeAPI64.dll [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: NvEncodeAPICreateInstance [h264_nvenc @ 000001c6a0c0ff00] Loaded sym: NvEncodeAPIGetMaxSupportedVersion [h264_nvenc @ 000001c6a0c0ff00] Loaded Nvenc version 9.0 [h264_nvenc @ 000001c6a0c0ff00] Nvenc initialized successfully
Results 1 to 1 of 1
Mov-Files- from camera-not working anymore in Windows Mediaplayer 11-WINXP
By 3dreal in forum Software PlayingReplies: 1Last Post: 26th Nov 2016, 10:34 -
nvenc hevc
By madhatr in forum Video ConversionReplies: 4Last Post: 19th Dec 2015, 19:07 -
nvenc compatibility
By amrel in forum Video ConversionReplies: 0Last Post: 29th Nov 2015, 11:02 -
bookmarking timestamps isnt working anymore though it used to
By BigDan in forum Newbie / General discussionsReplies: 4Last Post: 12th Sep 2015, 14:01 -
MakeMKV not working at all anymore. Need help!
By nateo200 in forum Blu-ray RippingReplies: 18Last Post: 30th Sep 2014, 22:16
