    mp4dash --widevine-header provider:widevine_test#content_id:2a --encryption-key aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa:bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb video-source.mp4
    2.
    [Attachment 49679 - Click to enlarge]
    [Attachment 49680 - Click to enlarge]
    [Attachment 49681 - Click to enlarge]
    mp4decrypt --key 1:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa --key 2:bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb init.mp4 out.mp4
    It doesn't work
    https://mega.nz/#!idpV3aDB!Er_zza8HedEJJ2I_-DZr8QPEPT6DoaRaFuClWShFkus
  2. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    First you have to merge those .m4s in to init.mp4 files with curl (video and audio separately),then merge video and audio with ffmpeg , then use the mp4decrypt.exe
    If you have managed to actually write the decryption key to use as aaaa and bbbb - good for you,if not - no chance to decrypt.
  3. Thanks for the reply
    How to merge video and audio with ffmpeg
    cat init.mp4 > v.mp4
    cat seg-1.m4s >> v.mp4
    cat seg-2.m4s >> v.mp4
    cat seg-3.m4s >> v.mp4
    cat init.mp4 > a.mp4
    cat seg-1.m4s >> a.mp4
    cat seg-2.m4s >> a.mp4
    cat seg-3.m4s >> a.mp4
    ffmpeg -i a.mp4 -i v.mp4 -vcodec copy -acodec copy enc.mp4
    ffmpeg version 3.2.14-1~deb9u1 Copyright (c) 2000-2019 the FFmpeg developers
      built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516
      configuration: --prefix=/usr --extra-version='1~deb9u1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
      libavutil      55. 34.101 / 55. 34.101
      libavcodec     57. 64.101 / 57. 64.101
      libavformat    57. 56.101 / 57. 56.101
      libavdevice    57.  1.100 / 57.  1.100
      libavfilter     6. 65.100 /  6. 65.100
      libavresample   3.  1.  0 /  3.  1.  0
      libswscale      4.  2.100 /  4.  2.100
      libswresample   2.  3.100 /  2.  3.100
      libpostproc    54.  1.100 / 54.  1.100
    [aac @ 0x5569b1ccc640] Number of bands (58) exceeds limit (37).
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'a.mp4':
      Metadata:
        major_brand     : isom
        minor_version   : 512
        compatible_brands: isomiso2avc1mp41iso5iso6
      Duration: 00:00:05.03, start: 0.000000, bitrate: 53 kb/s
        Stream #0:0(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 48 kb/s (default)
        Metadata:
          handler_name    : Bento4 Sound Handler
    [h264 @ 0x5569b1ce95e0] top block unavailable for requested intra mode -1
    [h264 @ 0x5569b1ce95e0] error while decoding MB 31 0, bytestream 33068
    [h264 @ 0x5569b1ce95e0] concealing 3060 DC, 3060 AC, 3060 MV errors in I frame
    Input #1, mov,mp4,m4a,3gp,3g2,mj2, from 'v.mp4':
      Metadata:
        major_brand     : isom
        minor_version   : 512
      Duration: 00:00:05.07, start: 0.000000, bitrate: 394 kb/s
        Stream #1:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1086x720 [SAR 1:1 DAR 181:120], 383 kb/s, SAR 10680:10679 DAR 89:59, 30 fps, 30 tbr, 15360 tbn, 60 tbc (default)
        Metadata:
          handler_name    : Bento4 Video Handler
    [mp4 @ 0x5569b1cfefc0] track 1: codec frame size is not set
    Output #0, mp4, to 'enc.mp4':
    Metadata:
        major_brand     : isom
        minor_version   : 512
        encoder         : Lavf57.56.101
        Stream #0:0(und): Video: h264 (Main) ([33][0][0][0] / 0x0021), yuv420p, 1086x720 [SAR 10680:10679 DAR 89:59], q
    =2-31, 383 kb/s, 30 fps, 30 tbr, 15360 tbn, 15360 tbc (default)
        Metadata:
        Stream #0:1(und): Audio: aac (LC) ([64][0][0][0] / 0x0040), 48000 Hz, stereo, 48 kb/s (default)
        Metadata:
    Stream mapping:
      Stream #1:0 -> #0:0 (copy)
      Stream #0:0 -> #0:1 (copy)
    Press [q] to stop, [?] for help
    frame=  152 fps=0.0 q=-1.0 Lsize=     272kB time=00:00:04.99 bitrate= 445.8kbits/s speed=1.31e+03x
    video:237kB audio:30kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 1.768678%
