Hi,
I have a video movie running at 29.97fps. When I burn it to DVD, using the Freemake Video Converter, which converts it into 25fps - I cannot alter that. The resulting DVD looks a tad jerky, especially on fast movement in the scenes.
I have Xmedia Recode Video Converter, which will let me convert to all of the popular kinds of frames per second. A few examples: 24 25 29.97 30 50 60 ...
Yes, I set the Freemake accelerator to off for a smoother burn. If I don't do this the videos are extremely jerky
Does anyone know if my video would be anymore steady if I was to convert the 29.97 fps over to, perhaps, 30 fps? Or will it not make a hapeth of difference? Remember, it burns to DVD as 25 fps..
Thanks in advance.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
True progressive 29.97 fps material isn't common (movies are usually shot at 24 fps). So your source is probably jerky to begin with. Converting it to 25 fps is going to make it more jerky. The difference between 29.97 and 30 fps is hard to see -- one little jerk every 33 seconds. But if you're making a authored movie DVD you can't make 30 fps.
One needs to see the source video to make specific recommendations.
FPS Upscaling issue
By syrpent in forum EditingReplies: 1Last Post: 8th Apr 2019, 19:24 -
How to make 1080i 59.940 FPS video to 29.970 FPS
By Joycon in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2018, 14:47 -
Convert 51.43 fps video in 59.94 fps container to straight 50 fps video
By mr_lou in forum Video ConversionReplies: 5Last Post: 8th May 2016, 12:47 -
convert 30 fps time lapse video to 60 fps to speed up and keep all frames
By acem77 in forum Video ConversionReplies: 12Last Post: 19th Jan 2016, 21:01 -
Playback Issue: Source Video with Inconsistent FPS
By ctr2yellowbird in forum Newbie / General discussionsReplies: 17Last Post: 21st Dec 2015, 21:45
