Why won't the DVD-R i copied not play in my DVD player when one i borrowed off a friend will. The copy i did will play in another DVD player i have. I have used verbatum & Packard Bell blank DVD's.
Can anybody help me or explain what i am doing wrong?
DVD player JVC XV-S42 which should play DVD-R
DVD writer Toshiba SD-R5002
AnonymousGuest
Possible answers:
Bad player - Your player is really old, circa early 2000's https://www.videohelp.com/dvdplayers/jvc-xv-s42/685#commentsand the DVD laser may be dying. This is the most likely since you're able to play the disc in another player.
Bad burner - Your burner just as old and again, the laser may be dying or incompatible with your discs.
Bad discs - Your Packard Bell discs are also old and were marginal quality at best. Even unopened, writable DVDs can go bad. As for Verbatim, what type of Verbatims? If they don't say AZO on the packaging or on the disc, it's marginal at best.
Bad burn speed - According to this page https://www.cnet.com/reviews/toshiba-sd-r5002-dvd-r-rw-kit-review/, your burner writes at 2X max, slow even for when it was new. If your Verbatims are new (8X or 16X), while may be possible to write at 2X, it's below the specs which requires at least 4X or 6X burn speed. The general rule is to write at 1/2 the max burn rating of your disc.
Bad burning software - If you're using anything but Imgburn, your software may be at fault.
Bad burn - What are your computer specs? If your computer is as old as your other equipment, you may be suffering from buffer underruns, where the burner is waiting for the data to be feed to the disc. Your can check for this by looking at the burned surface of your disc. The burned area should a smooth continuous light purple. If there's banding, that means the burn was interrupted by buffer underruns.
Best solution for the future - Toss your Packard Bell discs, they were never good to begin with and they're really old. If your Verbatims aren't AZO, toss them also and get some AZO discs (the only remaining good discs other than Taiyo Yudens which are very hard to find and more expensive). Upgrade your burner or use another one if you have it. As I stated above, it wasn't a quality drive even when it was new. You can continue to use your JVC player, but keep in mind that even if the DVD laser is still good, the electronics are slowly dying, even if you don't use the player frequently.Last edited by lingyi; 27th Jul 2019 at 08:04.
But why is the OP a guest ?
Problems playing back dvd after vhs to dvd transfer
By dirtspad in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2019, 10:58 -
Problems with playing 4k x265 files
By Teague in forum Software PlayingReplies: 7Last Post: 29th May 2019, 02:30 -
Problems playing back a DVD
By Basque in forum Authoring (DVD)Replies: 7Last Post: 23rd Jan 2018, 21:54 -
Problems playing .mkv on a LG BD550
By Pipster2797 in forum Blu-ray RippingReplies: 15Last Post: 9th Jan 2017, 07:53 -
DVD video color disappearing when playing VOB's, not when playing DVD
By lelegard in forum Video ConversionReplies: 6Last Post: 21st Aug 2016, 16:06
