The dvd +RW ejects when done copying a 2 minute movie, if I reinsert it to copy more, it wont allow me until I erase the previous content. The same with a -R disc, the 2 minutes takes up half the disc.
Any ideas? This is done on a RW drive on the pc.
If you want to add more movies after burning the first one you need to use multi session in your burning application.
Erase the disc and start a mulit session disc, burn the first movie. This way you can add another movie. -
If you want to treat a RW discs like a removable flash drive you need to use the Live File System. Format the drive from Explorer. You can then drag/drop files onto it just like a flash drive. Such discs won't play in a set-top DVD player though.
The "RW" tag means that you can erase it at all, completely though (in contrast to an "R" which you can only burn but not erase). But in general, DVD media are usually burned in a "Session At Once" mode. There are video cameras which burn onto 8 cm discs in an intermediate UDF file system; you have to finalize them before reading them on a PC (this adds a final generation of the UDF file system, as well as an ISO 9660 file system).
DVD Video specifications require a minimum filling of 1/3 capacity.
trying to download
By dizia in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2019, 04:52 -
I need help if it is okay to download...
By jarod1005 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2018, 11:47 -
Download from VK.com
By lordsmurf in forum Newbie / General discussionsReplies: 3Last Post: 19th Jul 2018, 01:44 -
How to download?
By siro in forum Video Streaming DownloadingReplies: 0Last Post: 27th Mar 2018, 01:06 -
Help to download
By supersport in forum Video Streaming DownloadingReplies: 3Last Post: 24th Aug 2016, 14:42
