  1. Just got a Rollei Family Action Cam with Full HD recording capabilities, and i was wondering if i can keep my old 64GB SD card rated class 10 XC1/U1. Just run a benchamrk from my Android phone on the SD Card. i got on a couple of tests
    1st Run R:16.82/W:10.77 MB/s
    2nd Run R:16.97/W:12.48MB/s
    https://kb.sandisk.com/app/answers/detail/a_id/8407/~/number-of-minutes-of-video-that-...-memory-device
    Which settings do you recommend i shall use for this camera?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Test both and see which works best or provides the output you want.
    Google is your Friend
