Hi!
Please guide regarding title how to remove Water mark or few seconds subtitle/text slide from video file.
Appreciate your prompt reply.
Results 1 to 10 of 10
You could use Delogo inside of VirtualDub. I created a short tutorial showing how to remove a small dust dot, but it was designed to remove logos and subtitles.
https://www.youtube.com/watch?v=Z12TutFSg8c -
VirtualDub2 is bitt difficult to inderstand and there is now user guide available for the filters of VirtualDub2 to remove sliding text from video. Any Advise ?
Bit similar to this, text slides from the right side, stop in the middle when complete, stay 6-8 secs and then start disappearing from the right (starting side).
You can get the filter here:
http://rationalqm.us/delogo132/delogo.html
Stick the VDF in the VDub2 Plugins folder and then you'll have the use of it. Here are tutorials:
http://rationalqm.us/delogo132/delogomanual/delogo.htm
I didn't use it in that video to which I linked earlier. I used the AviSynth filter InterpolateScanLines developed by jagabo here on Videohelp.com.Last edited by manono; 24th Oct 2019 at 20:02.
Wondershare Video Converter Ultimate 10.4.2 - Water Mark Possible?
By CarpentarMate in forum Video ConversionReplies: 2Last Post: 25th Feb 2019, 15:03 -
looking for tool to remove text from subtitle file
By klendathu in forum SubtitleReplies: 10Last Post: 21st Jan 2019, 13:46 -
How to make subtitle text appear over the video universally?
By kcheng in forum SubtitleReplies: 2Last Post: 6th Jan 2019, 19:14 -
certain subtitle lines showing as black text in multiple video players
By dstarfire in forum SubtitleReplies: 1Last Post: 22nd Feb 2016, 14:53 -
Video clip name - 5 seconds in start - subtitle
By pcspeak in forum EditingReplies: 0Last Post: 19th Dec 2014, 18:02
