authorization login+pass
Here is an example of molasses
http://video.old.beeline.tv/hls/hls_khl_sd/index.m3u8
http://bksmos02.beeline.tv:80/t0djtmmi5aaaaaaaaavk3ydaaaaaaaaaaaacebbgxjqkuazg/0009818...?bk-teardown=1
http://bksmos02.beeline.tv:80/t0djtmmi5aaaaaaaaavk3ydaaaaaaaaaaaacebbgxjqkuazg/0009818/01.m3u8
05.m3u8
This stream reproduces directly and through livestream example
"C:\Program Files\Portable\livestreamer-v1.12.2\livestreamer.exe" "hlsvariant://"http://video.old.beeline.tv/hls/match/index.m3u8 best
http://bksmos01.beeline.tv/t0djtmei5aaaaaaaaqjgxbcaaaaaaaaaaaake1uiyrqid0qi/0002976//G...?bk-teardown=1
http://bksmos02.beeline.tv/t0djtmei5aaaaaaaaqjgxbcaaaaaaaaaaaake1uiyrqid0qi/0002976/01.m3u8
http://bksmos02.beeline.tv/t0djtmei5aaaaaaaaqjgxbcaaaaaaaaaaaake1uiyrqid0qi/0002976/05.m3u8
hls-aes-cookie=0893039895+1564040819+02f9d6ef
need exactly this to reproduces
Results 1 to 14 of 14
livestreamer is outdated,use streamlink instead, the matchtv one worked for me. (same input commands)
Code:streamlink "http://video.old.beeline.tv/hls/match/index.m3u8" best [cli][info] Found matching plugin hls for URL http://video.old.beeline.tv/hls/match/index.m3u8 [cli][info] Available streams: 180p (worst), 270p, 288p, 396p, 576p (best) [cli][info] Opening stream: 576p (hls) [cli][info] Starting player: "C:\Program Files\VideoLAN\VLC\vlc.exe"
thanks I need the right stream that doesn't play http://video.old.beeline.tv/hls/hls_khl_sd/index.m3u8
C:\Windows\system32>"C:\Program Files\Streamlink\bin\streamlink.exe" "http://vid
eo.old.beeline.tv/hls/hls_khl_sd/index.m3u8" best
[cli][info] Found matching plugin hls for URL http://video.old.beeline.tv/hls/hl
s_khl_sd/index.m3u8
[cli][info] Available streams: 180p (worst), 270p_alt, 270p, 360p, 396p (best)
[cli][info] Opening stream: 396p (hls)
[stream.hls][error] Failed to create decryptor: Unable to open URL: https://auth
.iptv.beeline.ru/api/aeskey/hls_khl_sd/3/2606673.key (403 Client Error: Forbidde
n for url: https://auth.iptv.beeline.ru/api/aeskey/hls_khl_sd/3/2606673.key)
[cli][error] Try 1/1: Could not open stream <HLSStream('http://bksmos02.beeline.
tv:80/t0djtmmi5aaaaaaaaavk3ydaaaaaaaaaaaaeuymiyzqcebjg/0007641/05.m3u8')> (No da
ta returned from stream)
error: Could not open stream <HLSStream('http://bksmos02.beeline.tv:80/t0djtmmi5
aaaaaaaaavk3ydaaaaaaaaaaaaeuymiyzqcebjg/0007641/05.m3u8')>, tried 1 times, exiti
ng
[cli][info] Closing currently open stream... -
after each call changes
t0djtmmi5
aaaaaaaaavk3ydaaaaaaaaaaaaeuymiyzqcebjg/0007641/ -
Look here:Originally Posted by serejka
Code:https://4pda.ru/forum/index.php?showtopic=507935
here is the data
"method": "auth",
"params": {
"device-id": "f7157d3d-b7ef-39c0-ab41-6dfa11bf690a",
"device-type": "3",
"device-type-desc": "OnePlus ONEPLUS A3010",
"device-sw-version": "7.1.1",
"app-version": "",
"device-token": "",
"device-screen-resolution": "540x960",
"login": "",
"password": "",
"plain-password": "=="
https://auth.iptv.beeline.ru/api/auth
"result": {
"status": "ok",
"x-mstv-sso-identity": "SSOEWTTHFN4SWOWCPG2FVZQEIAZHESI7PDNY57AJXOBTOCKFZ 6FQOJNQSUPM6EIETE6NAWEJYGYGR5HDUUWDP2OKVQY7YPB625V GB2J6OPB75NFMQ4XUGZKNUHDG3EF6ZJWRDCHPTMCHB2IKBIS3A DI6MNLDPW3EK65V6GDFBDNKKLQGRKQHXZOGHMCVMMIALINZBC4 UD42J5IIS3CWU7NXXHCA3FE5FWZF4PSX5ZICZOCLFCADWD5ZD7 6QV27XG",
"hls-aes-cookie": "0893039895 1564052868 bfa6f304",
"has-iptv": true,
"has-master": true,
"pcon": "3310",
"apin": "3310",
"user-type": "FTTB",
"country-code": "RU"Last edited by serejka; 24th Jul 2019 at 18:25.
"method": "auth",
"params": {
"device-type": "3",
"app-version": "1.7.6",
"device-token": "f7157d3d-b7ef-39c0-ab41-6dfa11bf690a",
"login": "0890914678",
"password": "e99a18c428cb38d5f260853678922e03",
"plain-password": "YWJjMTIz"
https://auth.iptv.beeline.ru/api/aeskey/hls_khl_sd/3/2606696.key
http://bksmos01.beeline.tv/t0djtmei5aaaaaaaaqjgxbcaaaaaaaaaaaaie1agzbmad1qg/0010036/Gl...?bk-teardown=1
http://bksmos01.beeline.tv/t0djtmei5aaaaaaaaqjgxbcaaaaaaaaaaaaie1agzbmad1qg/0010036/01.m3u8
hls-aes-cookie=0890914678+1564060305+1cc20ef9
#EXTM3U
#EXT-X-INDEPENDENT-SEGMENTS
#EXT-X-STREAM-INF:BANDWIDTH=271315,AVERAGE-BANDWIDTH=180480,RESOLUTION=320x180,CODECS="avc1.4 2e00c,mp4a.40.2"
01.m3u8
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=271315,AVERAGE-BANDWIDTH=180480,RESOLUTION=320x180,CODECS="avc1.4 2e00c",URI="01-iframe.m3u8"
#EXT-X-STREAM-INF:BANDWIDTH=504194,AVERAGE-BANDWIDTH=335392,RESOLUTION=480x270,CODECS="avc1.4 2e015,mp4a.40.2"
02.m3u8
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=504194,AVERAGE-BANDWIDTH=335392,RESOLUTION=480x270,CODECS="avc1.4 2e015",URI="02-iframe.m3u8"
#EXT-X-STREAM-INF:BANDWIDTH=1037782,AVERAGE-BANDWIDTH=690336,RESOLUTION=480x270,CODECS="avc1.4 2e015,mp4a.40.2"
03.m3u8
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=1037782,AVERAGE-BANDWIDTH=690336,RESOLUTION=480x270,CODECS="avc1.4 2e015",URI="03-iframe.m3u8"
#EXT-X-STREAM-INF:BANDWIDTH=1501279,AVERAGE-BANDWIDTH=998656,RESOLUTION=640x360,CODECS="avc1.4 d401e,mp4a.40.2"
04.m3u8
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=1501279,AVERAGE-BANDWIDTH=998656,RESOLUTION=640x360,CODECS="avc1.4 d401e",URI="04-iframe.m3u8"
#EXT-X-STREAM-INF:BANDWIDTH=2891771,AVERAGE-BANDWIDTH=1923616,RESOLUTION=704x396,CODECS="avc1. 4d401e,mp4a.40.2"
05.m3u8
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=2891771,AVERAGE-BANDWIDTH=1923616,RESOLUTION=704x396,CODECS="avc1. 4d401e",URI="05-iframe.m3u8"
HTTP/1.1 200 OK
Server bks400
Date Thu, 25 Jul 2019 01:12:46 GMT
Content-Type application/vnd.apple.mpegurl
Content-Length 1296
Last-Modified Thu, 25 Jul 2019 01:19:40 GMT
Accept-Range bytes
X-HLS-INFO Variant Playlist
Expires Thu, 25 Jul 2019 01:12:45 GMT
Cache-Control no-cache
Access-Control-Allow-Origin *
X-Cache EXPIRED from bks400
Connection keep-alive
http://bksmos01.beeline.tv/t0djtmei5aaaaaaaaqjgxbcaaaaaaaaaaaaie1agzbmad1qg/0010036/20...-01-6235970.ts
HTTP/1.1 200 OK
Server bks400
Date Thu, 25 Jul 2019 01:12:47 GMT
Content-Type video/mp2t
Content-Length 206624
Last-Modified Thu, 25 Jul 2019 01:20:04 GMT
Accept-Range bytes
X-HLS-INFO Chunk
Expires Thu, 25 Jul 2019 01:12:46 GMT
X-Cache MISS from bks400
Connection keep-alive -
It's IPTVэто от beeline кхл ?
P.S. Look here :
https://4pda.ru/forum/index.php?showtopic=918513Last edited by sysanin; 26th Jul 2019 at 16:05.
Using VLC to stream tv channel
By tck9 in forum Video Streaming DownloadingReplies: 3Last Post: 18th Mar 2019, 04:08 -
Ripping IPTV Stream links from a website and play it in VLC
By yenchenje in forum DVB / IPTVReplies: 0Last Post: 28th Dec 2018, 06:27 -
MPEG 2 Extension for VLC? (VLC can't play its own recordings?!?!)
By gastrof in forum Newbie / General discussionsReplies: 17Last Post: 16th Dec 2018, 23:06 -
Stream Manoto via VLC
By Mumba in forum Video Streaming DownloadingReplies: 4Last Post: 17th Sep 2018, 12:20 -
VLC cannot play MPEG-2 (.mpg) file (VLC cannot identify the audio or ...)
By Jeppe in forum Software PlayingReplies: 6Last Post: 30th Jan 2018, 19:47
но это - IPTV (?!)
